I want to add some .tif images to geoserver but not through GUI provided in
it.I want to write a code in java which will take the path of image as input
and will save the data in geoserver.how can I do this?also can I do this
sitting on a remote server?
View this message in context: http://www.nabble.com/adding-data-to-geoserver-via-some-code-in-java-tp23920807p23920807.html
Use the REST configuration extension module:
http://geoserver.org/display/GEOS/Stable
Documentation here:
http://docs.geoserver.org/1.7.x/user/extensions/rest/index.html
Andrea Aime
OpenGeo - http://opengeo.org
