Same approach can be used in case the geotiff files
are part of a time series. Using ImageMosaic you can have them
associated to a single store/layer in GeoServer with a TIME dimension.
Simone Giannecchini
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
On Mon, Mar 11, 2013 at 2:46 PM, Andrea Aime
<andrea.aime@anonymised.com> wrote:
On Mon, Mar 11, 2013 at 2:36 PM, Gubler, Ruediger <rgubler@anonymised.com>
wrote:
Hello List,
I’m new to GeoServer and want to use it to provide GeoTiff over WMS.
We have aprox. 3000 GeoTiff files to add. Must we really add each file
manually as a datasource, publish the layer and add all layers each by each
to a group layer?
Is there no batch import for these types?
If they are part of the same overall image composite, then put them all in
the same folder and point
the image mosaic plugin to it as the source, it will do the rest and they
will be all published as a single
layer.
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
Symantec Endpoint Protection 12 positioned as A LEADER in The Forrester
Wave(TM): Endpoint Security, Q1 2013 and "remains a good choice" in the
endpoint security space. For insight on selecting the right partner to
tackle endpoint security challenges, access the full report.
http://p.sf.net/sfu/symantec-dev2dev
Geoserver-users mailing list
