[Geoserver-users] Adding multiple layers to layergroup via rest - perl/curl
Servus there,
i have a problem with a perl script wich i know worked sooner. with the new set of files to load - amount doubled aprox to 3000 - the server somewhen just stops and gives me an out of memory bubu.
i am running on a tomcat7, machine has 4 gigs o ram, xmlfile produced by layerscript is about 700M.
in the script i first build up the metadata from geotiff files, then create xmlfile to send to rest. I tried POST and PUTS as you can see...
so is the problem the ram of that machine or is my script bugfuggd?
thanx for help
nj
<snipp>
opendir(DIR, $f_dir) or die 'dumbo boogie' . $f_dir.'>>'. $!;
while (my $file = readdir(DIR)) {
print ">o>" . $file . "\t" . $EOL;
  # Use a regular expression to ignore files beginning with a period
  next if ($file =~ m/^\./);
  my $f_geotiff = $file .'/'. $file. '.geotiff';
  print ">>>>" . $file . "\t" . $EOL;
  print ">>>>" . substr($file,8,1)."\t".substr($file,9,2)."\t".substr($file,11,1)."\t".substr($file,12,3) . "\t" . $EOL;
  # need to add to layergroup
  # done in post fileitem handling
  # $geos_layers [NortOrSouth][{{:digit:}}[2]][EastOrWest][{{:digit:}}[2]]
  $geos_layers{substr($file,8,1)}{substr($file,9,2)}{substr($file,11,1)}{substr($file,12,3)} = $file;
closedir(DIR);
print ">>T>>" . $f_temp . "\t" . $EOL;
# namespace fixups
# not needed, because workspace must be present...20121225
#my $crNamespacefixups = `curl -u $geos_user:$geos_passwd -v -XPUT -H 'Content-Type: application/xml' -d '<namespace><prefix>$geos_workspace</prefix><uri>http://nuttijay.is-a-geek.org/$geos_workspace&lt;/uri&gt;&lt;/namespace&gt;&#39; http://$geos_host:$geos_port/geoserver/rest/namespaces/$geos_workspace`;
#print '++>' . $crNamespacefixups . $EOL .'<++' .$EOL;
my $geos_layerlistxml;
my $geos_styleslistxml;
my $geos_layergroupxml;
my $f_temp = $f_tempdir.$geos_workspace.'.xml';
# tempfilecleanup
if (-s $f_temp) {
  `rm $f_temp`
open (MYFILE, ">>$f_temp");
print MYFILE '<?xml version="1.0" encoding="UTF-8"?>';
print MYFILE '
<layerGroup>
   <name>' . $geos_layergroup. '</name>
   <layers>
foreach my $l_lattype ( sort keys %geos_layers ) {
# print "+pling+Lt+ " . $l_lattype . $EOL;
  foreach my $l_latval ( reverse sort keys %{ $geos_layers{$l_lattype} } ) {
# print "+pling+Lv+ " . $l_latval . $EOL;
    foreach my $l_lontype ( sort keys %{ $geos_layers{$l_lattype}{$l_latval} } ) {
# print "+pling+LT+ " . $l_lontype . $EOL;
      foreach my $l_lonval ( sort keys %{ $geos_layers{$l_lattype}{$l_latval}{$l_lontype} } ) {
# print "+pling+lV+ " . $l_lonval . $EOL;
# $geos_layerlistxml .= '<layer>' . $geos_layers{$l_lattype}{$l_latval}{$l_lontype}{$l_lonval} . '</layer>';
        $geos_layerlistxml .= '<layer>' . $geos_csname_prefix.$l_lattype.$l_latval.$l_lontype.$l_lonval . '</layer>';
        print MYFILE $geos_layerlistxml;
        $geos_styleslistxml .= '<style>demFull</style>';
print MYFILE '</layers>
   <styles>
        print MYFILE $geos_styleslistxml;
print MYFILE '</styles>
</layerGroup>';
close (MYFILE);
#print 'http://' .$geos_host. ':' .$geos_port. '/geoserver/wms/reflect?layers=' . $geos_layergroup . $EOL;
#my $crLayerGadd = `curl -u $geos_user:$geos_passwd -XPUT -H 'Content-type: application/xml' -d '$geos_layergroupxml' http://$geos_host:$geos_port/geoserver/rest/workspaces/$geos_workspace/layergroups.xml`;
my $crLayerGadd = `curl -vv -u $geos_user:$geos_passwd -XPOST -D $f_temp.txt -T $f_temp -H "Content-type:text/xml" --location http://$geos_host:$geos_port/geoserver/rest/layergroups`;
print "$crLayerGadd" .$EOL;
print '+=> ' .$crLayerGadd . $EOL . '<+=' . $EOL;
sub sendData() {
$geos_layergroupxml = '<layerGroup>
   <layers>
  ' .$geos_layerlistxml. '
   </layers>
   <styles>
     ' .$geos_styleslistxml. '
   </styles>
</layerGroup>';
print '+=> # # # # # # # # # # # # # <+=' . $EOL;print '+=> # # # # # # # # # # # # # <+=' . $EOL;
print $geos_layergroupxml . $EOL;
## exec block
#my $crLayerGadd = `curl -u $geos_user:$geos_passwd -XPOST -H 'Content-type: application/xml' -d '$geos_layergroupxml' http://$geos_host:$geos_port/geoserver/rest/workspaces/$geos_workspace/layergroups.xml`;
$geos_layerlistxml = '';
$geos_styleslistxml = '';
$geos_layergroupxml = '';
<snapp>
