[Geoserver-users] Adding Style through Rest
Hello,
I am running into an issue with adding a style to an existing layer via API in Python.
The existing layer has 1 style and I want to add a send.
{"styles":{"style":[{"name":"tp_raster_ramp","href":"https:\/\/[myserver.com](http://myserver.com)\/geoserver\/rest\/layers\/bambarahar\/styles\/tp_raster_ramp.json"}]}}
{"styles":{"style":[{"name":"tp_raster_ramp","href":"https:\/\/[myserver.com](http://myserver.com)\/geoserver\/rest\/layers\/applehar\/styles\/tp_raster_ramp.json"},{"name":"tp_raster_generic","href":"https:\/\/[geoserver.terrapop.org](http://geoserver.terrapop.org)\/geoserver\/rest\/layers\/applehar\/styles\/tp_raster_generic.json"}]}}
My question is what I put in the payload. Currently, I have been constructing both styles via json object but I keep getting an class errors.
[http://docs.geoserver.org/stable/en/user/rest/api/layers.html](http://docs.geoserver.org/stable/en/user/rest/api/layers.html)
David Haynes, Ph.D.
Research Associate Terra Populus
Minnesota Population Center
612-626-3933
www.terrapop.org
Hi David,
you might want to look at what gsconfig does (or just use it):
https://github.com/boundlessgeo/gsconfig
On Thu, Mar 17, 2016 at 4:53 PM, David Haynes II <dahaynes@anonymised.com> wrote:
Hello,
David Haynes, Ph.D.
612-626-3933
www.terrapop.org
Transform Data into Opportunity.
Accelerate data analysis in your applications with
Intel Data Analytics Acceleration Library.
Click to learn more.
http://pubads.g.doubleclick.net/gampad/clk?id=278785231&iu=/4140
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Andrea,
Thanks for pointing me to that library. Seems like most of the pieces are there.
On another topic are you or anyone from Geoserver presenting at FOSS4g in Bonn? I know there have been a couple of tutorials and I’d definitely send a colleague of mine to attend the workshop if one was going to be held.
On Thu, Mar 17, 2016 at 11:05 AM, Andrea Aime <andrea.aime@anonymised.com107…> wrote:
Hi David,
Hello,
David Haynes, Ph.D.
612-626-3933
www.terrapop.org
Ing. Andrea Aime
@geowolf
Technical Lead
David Haynes, Ph.D.
612-626-3933
www.terrapop.org
