Hello,
I'm new to GeoServer and to GIS in general so please accept my
apologies if my question is not a very good one:
I have a shapefile defining the county boundaries for my state and
have a dataset of counts-per-counties, attributes not found in the
shapefile.
I would like to present these data via WMF/WMS as appropriate with a
styled layer descriptor file which discriminates based on my
counts-per-county attribute. Should I add my attributes to the
shapefile itself, or is there some way I can keep these data external
to the shapefile and have GeoServer do a "join" on them before
presentation?
michael
Unfortunately there's no way to do an on-the-fly join. We hope to get there, but it's a pretty hard problem. So you'll have to add the attributes to the shapefile yourself.
best regards,
Chris
Michael Heuer wrote:
Hello,
shapefile.
presentation?
michael
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier.
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-users mailing list
!DSPAM:1003,45c390ff48021510810322!
Chris Holmes
The Open Planning Project
http://topp.openplans.org
Thanks.
What if my shapefile is imported into a different datasource, say PostGIS?
Then would it be possible to include a calculated column in the
result, or use SQL to do joins to other database tables? Essentially,
something like
SELECT ..., t1.value as value FROM mytable_postgis t0, my_other_table t1 WHERE
the_geom && <bounding box of the search polygon> -- this is the
spatial index operation
AND intersects(the_geom, <the polygon> ) -- this is the full OGC
spatial operation
AND t0.population > 1000000
AND t0.some_primary_key = t1.primary_key;
michael
best regards,
Chris
> Hello,
> shapefile.
> presentation?
> michael
> Geoserver-users@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-users
Chris Holmes
On 2/2/07, Michael Heuer <heuermh@anonymised.com> wrote:
Thanks.
Yes.
Alex
Thanks.
Yes.
You do have to register it as a view though in PostGIS (which takes a couple tweaks to work in GeoServer, see http://docs.codehaus.org/display/GEOSDOC/PostGIS+DataStore, or create a new table that has the results of the join.
Chris
Alex
!DSPAM:1003,45c3aaf070581775926497!
Chris Holmes
Hello Chris,
I'm not sure a view gets me where I want.
It's a stretch of an example, but say I had the election results per
county for 10000 races:
table election_result:
candidate_id county_id votes_cast
0 0 100000
1 0 200000
9999 100 150000
The query would include candidate_id = ? and the resulting features
should include votes_cast as an attribute so they can be styled
accordingly.
select ..., e.votes_cast from county_postgis c, election_result e
where ...
AND c.county_id = e.county_id
michael
>> Thanks.
> Yes.
Chris
> Alex
Chris Holmes
Alternatively, as long as I include a primary key as an attribute,
perhaps I can just be clever in generating the style document.
michael
Hello Chris,
0 0 100000
1 0 200000
9999 100 150000
accordingly.
where ...
michael
> >> Thanks.
> > Yes.
> Chris
> > Alex
> > _______________________________________________
> Chris Holmes
I'm pretty sure that anything you can put in a join you can make a view of... Some of the SQL experts on the list can probably give you better advice on how to structure it though.
Chris
Hello Chris,
0 0 100000
1 0 200000
9999 100 150000
accordingly.
where ...
michael
Thanks.
Yes.
Chris
Alex
Chris Holmes
!DSPAM:1003,45c3bfef88371194215290!
Chris Holmes
Michael Heuer ha scritto:
Hello,
shapefile.
presentation?
Taking into consideration the other mails in this thread, I'd suggest:
* load the shapefile and your counts per county information into two
separate postgis tables
* create a view that joins them and register it against geometry_columns:
create view county_votes as select * from county join election_result on county.id = election_results.county_id
insert into geometry columns ... (see the other spatial tables to
guess the attributes, you have to register the geometric column in
your view so that Geoserver knows about it, its nature and spatial
reference system).
* connect the postgis datastore and register the conty_votes view as
a feature type
* generate on the fly an sld with a filter over the candidate_id you
want to map, and link the color to the vote number (this sld document
is going to become big).
* use the generated sld in your WMS requests, putting it in the SLD_BODY
request field.
That should be (more or less) it.
