Hi Matthew,
Maybe this is out of the discussion but...
Have you considered using WFS? I am using WMS to present the layers
and WFS to get the details when the user click. With WFS you will be
able to:
-Set the buffer, tolerance of the click by units of measurement.
-Get the data in XML and trasnform it to any other format like HTML.
-Decide how many features you want to get when the user click and
there are several features behind a point. You can decide to get them
all, to get only one, etc...
-Decide the data, properties, that you want the server to return to you.
And many more things...
Javier.
On 16/06/2006, at 0:11, Matthew Perry wrote:
While we're at it, I have two additional question for the list
regarding GetFeatureInfo requests:
* Is there a way, other than recompiling the servlet, to adjust the
html layout of the output? Some configuration file perhaps?
* Is there a way to support info on multiple features at the same XY?
My initial experience says that only one feature is returned when
there may be many features at the query point.
Matthew Perry
On 6/15/06, Ralph Buchfelder <Ralph.Buchfelder@anonymised.com> wrote:
QUESTION 1:
how is your X and Y parameter set/pixel coordinate system implemented?
0,0 in the upper left corner?
QUESTION 2:
where can i configure the "snapping" for focussing getFeatureInfo in
server administration?
i.e. adjust the snapping tolerance in pixel?
QUESTION 3:
why does parameter I and J according to OGC WMS Specs
(http://portal.opengeospatial.org/files/?artifact_id=14416)
return an error?
Matt Perry
perrygeo@anonymised.com
http://www.perrygeo.net
Geoserver-users mailing list
