[Geoserver-users] Advanced customisation of GeoServer logging
I’m trying to improve my GeoServer logging and I can’t see any instructions online to deal with the ‘Could not find layer’ log entries.
If I make an incorrect request for a layer which doesn’t exist it generates a ServiceException and this includes a log entry which is flagged as an ‘ERROR’ and includes a stack trace with over 100 lines of text. We use OpenLayers so if a layer is misconfigured you can get an idea of how much this clogs up the log file.
Given that I am using PRODUCTION logging I would like to limit this particular log entry to a single line (or two if required). My ideal log entry would be:
“2015-08-17 10:52:49,350 INFO [geoserver.ows] - org.geoserver.platform.ServiceException: Could not find layer workspace:layername”
I’m aware that others may want it recorded as an ERROR but for me I don’t want it to do that unless I switch to a different logging level (i.e. DEBUG or VERBOSE) for that particular error. To me, this is an incorrect user request it is not an actual error in GeoServer; I doubt it is handled in the same way if you do a catalog query?
Is there a way to set how particular errors are handled in the logging settings or are the settings limited to filtering on error type only?
Paul
On Mon, Aug 17, 2015 at 12:10 PM, Wittle, Paul <P.Wittle@anonymised.com>
wrote:
I'm trying to improve my GeoServer logging and I can't see any
instructions online to deal with the 'Could not find layer' log entries.
If I make an incorrect request for a layer which doesn't exist it
as an 'ERROR' and includes a stack trace with over 100 lines of text. We
entry would be:
"2015-08-17 10:52:49,350 INFO [geoserver.ows] -
workspace:layername"
I'm aware that others may want it recorded as an ERROR but for me I don't
There is almost no distinction between user and internal error inside
GeoServer. I say almost because some errors end up being wrapped
in an exception with a OGC specific code, which can in some cases be used
to infer that an error is a user error.
These users codes are spread out in the code base and are OGC version and
protocol dependent, which makes things somewhat harder.
The exception logger is centralized, it gets all exceptions, and already
tries not to log the ones that originate from a client
closing the HTTP connection in GeoServer face, but that's all.
With some refactoring we could indeed have that centralized logger tone
down the user errors that are immediate to be recognized,
at least a few ones, and then over time classify the exceptions better so
that more and more user are recognized as such.
E.g. if I'm guessing correctly your error is created as:
      throw new ServiceException("Could not find layer " + layerName,
"LayerNotDefined", "layers");
We would have to refactor that string into an enumeration of sort, mark the
enumeration entries
as being (or not) user errors, and then modify the Dispatcher so that it
can recognize the user
errors. As said, what makes it annoying is that across the various
protocols we have usage of
free strings (in the oldest, like WMS above), strings backed by constants,
and custom made enums,
like in WCS 2.0 where we have a HTTP code associate by spec with each
exception class
(fun fact, that is not shared wtih WCS 1.0 and 1.1... which use strings
instead).
Welcome to the pleasure of working against a 13 years old codebase :wink:
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Hi Paul,
You don’t specify what version of GeoServer you’re using, but about… 18 months ago?.. around 2.5 I think, Warwickshire CC sponsored some work to get the logs cleared up a bit. At the time I believe Andrea noted that was the first time anyone had done any work cleaning the logs, so if you’re using a more recent version then the logs should hopefully have much less spurious stuff in them than they used to.
So if you want better logging (and I’m completely with you on that), it may be worth “sponsoring” (funding) it. Like WCC, you could get some support which includes developer time, it’s cheaper than the proprietary licenses and we figured it was a good use of taxpayer money rather than just making the likes of ESRI richer (I make such a poor capitalist J ).
Jonathan
From: Wittle, Paul [mailto:P.Wittle@anonymised.com]
Sent: Monday, August 17, 2015 11:10 AM
Subject: [Geoserver-users] Advanced customisation of GeoServer logging
Paul
“This e-mail is intended for the named addressee(s) only and may contain information about individuals or other sensitive information and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this email in error, kindly disregard the content of the message and notify the sender immediately. Please be aware that all email may be subject to recording and/or monitoring in accordance with relevant legislation.”
This message has been scanned for viruses by MailControl, a service from BlackSpider Technology
Click here to report this email as spam.
Thanks for your email but it’s generally best to send emails to the mailing list rather than individuals, that way other people can potentially help and benefit from the solution if one is found.
Unfortunately your email doesn’t include enough information about what the problem is, and I don’t speak Spanish(?) I’m afraid so it’s not clear what the error says.
I’d suggest the following information:
  • Version of GeoServer
  • What you’re doing to trigger the error.
  • What happens when you trigger the error
  • What the expected output is.
And any other information that may help in diagnosing the problem is also useful.
Jonathan
From: Máximo Acuña [mailto:helpdesk_max@anonymised.com]
Sent: Monday, August 17, 2015 4:48 PM
To: Jonathan Moules
Subject: RE: [Geoserver-users] Advanced customisation of GeoServer logging
hi jonathan
I need your help
I 'm publishing a WMS but I get the following error
everything I'm working from my server on Linux 6.5
help !!
To: P.Wittle@anonymised.com; geoserver-users@lists.sourceforge.net
Date: Mon, 17 Aug 2015 15:09:55 +0000
Subject: Re: [Geoserver-users] Advanced customisation of GeoServer logging
Hi Paul,
Jonathan
Paul
HR Wallingford and its subsidiaries uses faxes and emails for confidential and legally privileged business communications. They do not of themselves create legal commitments. Disclosure to parties other than addressees requires our specific consent. We are not liable for unauthorised disclosures nor reliance upon them.
If you have received this message in error please advise us immediately and destroy all copies of it.
HR Wallingford Limited
Howbery Park, Wallingford, Oxfordshire, OX10 8BA, United Kingdom
Registered in England No. 02562099
_______________________________________________ Geoserver-users mailing list Geoserver-users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-users
