[Geoserver-users] Advanced Dispatch Filter in geoserver
How to disable the Advanced Dispatch Filter on geoserver:
Thx
Jairo de Almeida
email: jairodealmeida@anonymised.com
nome skype: jairodealmeida
On Tue, Oct 28, 2014 at 2:55 PM, Jairo de Almeida <jairodealmeida@anonymised.com>
wrote:
Not sure if it can be done without breaking GeoServer....
Why do you need to do that?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
The way would be to comment out the filter and mapping in web.xml. But as Andrea says things will break if it’s gone.
On Tue, Oct 28, 2014 at 7:31 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Geoserver-users mailing list
Justin Deoliveira
VP Engineering | Boundless
jdeolive@anonymised.com
@boundlessgeo
On Tue, Oct 28, 2014 at 2:55 PM, Jairo de Almeida <jairodealmeida@anonymised.com> wrote:
Not sure if it can be done without breaking GeoServer…
Ing. Andrea Aime
@geowolf
Technical Lead
