[Geoserver-users] Advertised option in Layer Edit
Hello
I’m new to Geoserver, however I’ve used the Advertised tick box to hide layers from corporate software WMS connections. I unticked it for anything I didn’t want to be visible in MapInfo WMS, or any other WMS and this worked until recently.
However since an upgrade to 2.3.3 they are all showing again, but the Advertised option is still unticked. Does anyone know has this functionality been discontinued, it still works in 2.3.0
Thanks for any help
Sandra
Hi Sandra,
It works fine for me (2.3.4). A layer that isn’t set to “advertised” doesn’t show up in either the WMS 1.1.1 or 1.3.0 GetCapabilities.
If you open the GetCapabiltities documents directly (use the links on the GeoServer Admin page), are the layers listed there?
I’m not sure why you’d get this behaviour.
Jonathan
On 5 August 2013 11:03, Sandra Kennish <s.kennish@anonymised.com> wrote:
Hello
Thanks for any help
Sandra
CONFIDENTIALITY: The contents of this message are the views of the author, not necessarily the views of the North York Moors National Park Authority. This is a private message intended for the named addressee(s) only. Its contents may be confidential.
If you have received this message in error please reply to say so and then delete the message. Any use, copying, disclosure or distribution by anyone other than the addressee is forbidden.
www.northyorkmoors.org.uk
Get your SQL database under version control now!
Version control is standard for application code, but databases havent
caught up. So what steps can you take to put your SQL databases under
version control? Why should you start doing it? Read more to find out.
http://pubads.g.doubleclick.net/gampad/clk?id=49501711&iu=/4140/ostg.clktrk
Geoserver-users mailing list
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
Hi Sandra,
(I think we lost the list there for a bit).
So what was the solution? Changing back to 1.1.1? Do the not-advertised layers still appear in the 1.3.0 GetCapabilities then?
If so it may be worth reporting this as a bug (see - http://docs.geoserver.org/latest/en/user/introduction/gettinginvolved.html#bug-tracking ). Be sure to include copies of the GetCapabilities for both versions.
Now to find a way of getting rid of my Layer Groups so they don’t show…
I did look into that as part of testing your issue, but couldn’t see an explicit option. However LayerGroups do inherit at least some stuff from their component layers, so if /all/ layers in a layer group are set to not-advertised I’d hope/expect the layerGroup would then be notAdvertisied. Just guessing there though.
Kind Regards,
Jonathan
On 5 August 2013 12:13, Sandra Kennish <s.kennish@anonymised.com> wrote:
Hi Jonathan
Ok I think I’ve sussed it:
I can definitely see the hidden layers in MapInfo (v12) and load them, using just http://example.com/geoserver/wms/,
1.3 doesn’t work at all http://example.com/geoserver/wms?service=wms&version=1.3.0&request=GetCapabilities
But changing 1.3 to 1.1 in the url works and removes my hidden layers.
The SRS I would love to change, however it’s a shared server and I have to get permission to change anything, but if we are to use the server to host any WMS it does need sorting.
Thanks for your help – much appreciated.
Sandra Kennish
From: Jonathan Moules [mailto:jonathanmoules@anonymised.com]
Sent: 05 August 2013 11:40
To: Sandra Kennish
Subject: Re: [Geoserver-users] Advertised option in Layer Edit
Hi Sandra,
The “ows” one is “preferred” as I understand it. It can be used for both WMS and WFS for one thing.
However, whether I use:
http://example.com/geoserver/ows?service=wms&version=1.3.0&request=GetCapabilities
or
or
http://example.com/geoserver/wfs?service=wms&version=1.3.0&request=GetCapabilities (strictly speaking this is wrong for obvious reason :wink: )
in all cases if a layer is advertised=false then it won’t be included in the resultant file.
The error you’re getting looks like an Internet Explorer thing. It doesn’t like XML much. Try a different browser on the 1.1.1 getCapabilties. Or saving the file to your computer and looking at it in notepad or the like. That should hopefully get you the complete file.
Another thing - You should probably limit your list of SRS’s. In the admin page, click “WMS”. On this page there’s an option called “limited SRS list” - add the coordinate systems that you’re likely to use. Probably just 27700 and 4326 - the one’s listed in your email are for central Europe and the North York Moors aren’t /that/ big. :slight_smile:
It’s a small optimisation, but it might make the file easier for IE to parse given that’s where it’s failing.
Jonathan
On 5 August 2013 11:26, Sandra Kennish <s.kennish@anonymised.com> wrote:
Hi Jonathan
Thanks for your reply.
If I view it from the admin, the url ends like this geoserver/ows?service=wms&version=1.3.0&request=GetCapabilities
Then the layers aren’t visible here.
The url that I’ve always used has wms instead of ows and its that shows all the layers, however that xml page has an error at the bottom
Cannot view XML input using XSL style sheet. Please correct the error and then click the Refresh button, or try again later.
The following tags were not closed: WMS_Capabilities, Capability, Layer, CRS. Error processing resource 'http://
nt:-2em"> EPSG:32626
EPSG:32627
EPSG:32628
EPSG:32629
EPSG:32630
SSShould I be using the ows one?
Sandra
Sent: 05 August 2013 11:16
To: Sandra Kennish
Hi Sandra,
Jonathan
Hello
Thanks for any help
Sandra
Scanned by MailDefender - managed email security from intY - www.maildefender.net
Hi Jonathan
Changing the url we use in MapInfo back to 1.1.1 lets me connect and see the filtered list.
Using 1.3.0 results in an xml error, can’t connect at all.
And chopping the url off at the /wms results in us seeing everything (which is what I used when the 1.3.0 url wouldn’t work.
I don’t think that hiding all the layers in a Layer Group results in the Layer Group being hidden, as several of mine are set to that and I can still see them. Also I have added my database/workspace name into the url so I can only see those layers, and that hasn’t filtered out Layer Groups which use a different workspace/database either.
Sandra
Sandra Kennish
Kind Regards,
Jonathan
Hi Jonathan
Sandra Kennish
To: Sandra Kennish
Hi Sandra,
or
or
Jonathan
On 5 August 2013 11:26, Sandra Kennish <s.kennish@anonymised.com37…> wrote:
Hi Jonathan
EPSG:32627
EPSG:32628
EPSG:32629
EPSG:32630
Sandra
To: Sandra Kennish
Hi Sandra,
Jonathan
On 5 August 2013 11:03, Sandra Kennish <s.kennish@anonymised.com37…> wrote:
Hello
Thanks for any help
Sandra
