Chiming in a bit late. Those performance benchmarks are based on very simple styles (no thematics, no labels, etc..) so depending on your SLD you could be hitting a case where the render is just slow. Although I do suspect something else is off if its an order of magnitude slower than mapserver.
It would help if you included your SLD and if possible some of your data (a postgis dump would do). That way one of us could run the requests here (in a profiler if necessary) to see what exactly is going on.
Hey folks,
Yeah -- I'm connecting to the same exact postgis database with mapserver, and generating the map is an order of magnitude faster. I may have to switch over to mapserver, but I would very much prefer not to. Is there a benchmark test that involved rendering ~800k points? My points heavily overlap, which could be a factor -- my map is all geonames features in Africa.
--j
On Mon, Jul 21, 2008 at 11:53 AM, Chris Holmes <cholmes@anonymised.com <mailto:cholmes@anonymised.com>> wrote:
With MapServer you're connecting to the exact same postgis database?
And it's an order of magnitude faster?
Shapefiles should be a bit faster than PostGIS, but not that much.
And the differences should be about the same between GeoServer and
MapServer, see
http://www.foss4g2007.org/presentations/view.php?abstract_id=120
Chris
Josh Marcus wrote:
Chris,
Thanks for the help!
I've tried it with 1.6.x and the performance seems pretty similar.
I exported my postgis data into a shapefile, and the performance
with the shapefile is quite good (I haven't tried filtering
yet). So it seems like an issue with Postgis or
Postgis/Geoserver interaction. If I put a filter on the points
that reduces the number of points to under 50k, the performance
is much better.
Maybe it's an issue with the way I set up my postgis table? I
added a spatial index and clustered based on the spatial index...
Any additional advice would be greatly appreciated. Again, let
me know if there is information I can share that would be
helpful for diagnosis.
--j
On Fri, Jul 18, 2008 at 6:10 PM, Chris Holmes
Are you using nightlies? Or beta-1? We know that performance
dropped for 1.7.x, and made recent efforts to fix it. Though
maybe
only shapefile got better.
Could you try it with 1.6.x and see if that's fast? And then
if you
are on the latest nightlies it sounds like we should get our
profiler out and see if we have the same issues with postgis.
A lot
changed with 1.7.x, so it's quite possible it's slower. Thanks a
ton for bringing up the issue.
best regards,
Chris
Josh Marcus wrote:
Hey there,
I'm using 1.7.x and my jdk is 1.6, and I've isolated that my
issue is postgis related, as I dumped my postgis data into a
shapefile -- and that renders quite quickly.
--j
On Fri, Jul 18, 2008 at 5:31 PM, Chris Holmes
<mailto:cholmes@anonymised.com>>> wrote:
What version of GeoServer are you using? It should be
just
as fast
as MapServer for most all renderings with 1.6.x. One
thing
may be
to install java advanced imaging, though I think we don't
depend on
that for speed as much as we used to. And be sure
that your
jdk is
1.6, 1.4 is half as slow.
http://geoserver.org/display/GEOSDOC/2.6+GeoServer+in+Production+Environment
has more hints on running in a production environment, and
may have
some more tips.
Chris
Josh Marcus wrote:
David,
Thanks for the advice! However, I need to apply
dynamic
SLDs
-- so I will need to actually optimize the speed
of the map
generation. Mapserver can generate the same maps
almost an
--j
On Fri, Jul 18, 2008 at 4:05 PM, David Winslow
<dwinslow@anonymised.com
<mailto:dwinslow@anonymised.com> <mailto:dwinslow@anonymised.com
<mailto:dwinslow@anonymised.com>>
<mailto:dwinslow@anonymised.com>>>
<mailto:dwinslow@anonymised.com>> <mailto:dwinslow@anonymised.com
<mailto:dwinslow@anonymised.com>>>>> wrote:
Probably the easiest (and most effective) way to
improve WMS
performance is to set up a tile cache for your WMS.
GeoWebCache and
TileCache are two fairly easy options. GeoWebCache
even has a
plugin available for GeoServer.
http://geowebcache.org/
http://tilecache.org/
Hope this helps,
-David Winslow
Josh Marcus wrote:
Hey there,
I'm looking for some advice about how to
speed up
responses to
WMS requests for a map I'm generating. The map
consists
of 800k
points, stored in Postgres (with a spatial
index and
clustered),
and at this point I'm displaying it with
the default
point SLD.
It can take as long as 45 seconds to
render. I've
played with
the various renderer configurations ... but I'm
not sure
how to
profile or improve the performance at this
stage. Any
advice?
Any additional information I can provide?
Thanks so much, --j
This SF.Net email is sponsored by the
Moblin Your Move
Developer's challenge
Build the coolest Linux based applications
with Moblin
SDK & win
great prizes
Grand prize is a trip for two to an Open
Source event
anywhere
in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
<http://moblin-contest.org/redirect.php?banner_id=100&url=/>
<http://moblin-contest.org/redirect.php?banner_id=100&url=/>>
<http://moblin-contest.org/redirect.php?banner_id=100&url=/>>>
<http://moblin-contest.org/redirect.php?banner_id=100&url=/>>>>
Geoserver-users mailing list
<mailto:Geoserver-users@lists.sourceforge.net>
<mailto:Geoserver-users@lists.sourceforge.net>>
<mailto:Geoserver-users@lists.sourceforge.net>>>
<mailto:Geoserver-users@lists.sourceforge.net>>>>
This SF.Net email is sponsored by the Moblin Your Move
Build the coolest Linux based applications with Moblin
SDK & win
great prizes
Grand prize is a trip for two to an Open Source event
anywhere
in the world
!DSPAM:4005,488101b977873327367457!
!DSPAM:4005,48810dce98281012714783!
!DSPAM:4005,4884ad62169228992556831!
!DSPAM:4007,4884fb0b57845210051143!
This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
Build the coolest Linux based applications with Moblin SDK & win great prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
