[Geoserver-users] Advice regarding HTTP Servers & GeoServer
Hi John,
  Sounds like an interesting(ambitious) project. For Geoserver all you
need to do is copy the geoserver.war into the Tomcat webapps directory and
you will be able to http://localhost:port/geoserver The port is whatever you
set for the Tomcat, possibly :8080
  You might want to uninstall the Jetty version or at least run the
stop bat. I think you might also want to run only one Tomcat at a time.
  Once you have browser access to the geoserver admin you can read the
documentation on configuring a DataStore/Style/FeatureType against your
PostGIS table(s)
  It would be interesting to hear how you fare. So far I've been so
pleased with Geoserver that I haven't tried MapGuide or Degree. I think it
fits into a Java backend better than the others you mentioned. Feed back
from other perspectives is always helpful.
randy
-----Original Message-----
From: geoserver-users-bounces@lists.sourceforge.net
[mailto:geoserver-users-bounces@lists.sourceforge.net] On Behalf Of John
Roberts
Sent: Friday, March 02, 2007 7:31 AM
Subject: [Geoserver-users] Advice regarding HTTP Servers & GeoServer
Dear All
Please could somebody help with my query, either some advice on where to go
to get the information or the information itself!
I have my spatial data loaded in a PostGIS database and I want to install
MapServer, GeoServer, Deegree and MapGuide Open Source on the same windows
computer which would allow me to compare and contrast the products.
I thought that I would therefore install the latest version of Apache HTTP
server and run all of the products from the same Apache HTTP server.
What I am not sure about is:
1. I have gathered that GeoServer can be run using Apache Tomcat. How do I
configure GeoServer so that it is running from Apache Tomcat and not from
Jetty?
2. I have looked the Apache site, and the Apache Tomcat 6.0 contains its own
HTTP server internally. Therefore if I have already installed Apache HTTP
server, I will be have 2 HTTP servers installed. Can I link the Tomcat to
the independent installation of Apache HTTP server or can I use the HTTP
server bundled with the Tomcat as a HTTP server in its own right?
3. If I do install Apache and get GeoServer to run from it, how do I stop
Jetty starting up when I start Geoserver going?
Any help would be very much appreciated!
Kind Regards
John
Manchester, UK
opinions on IT & business topics through brief surveys-and earn cash
Geoserver-users mailing list
