After I restart my server then an existing "Postgis" datastore has the
enable checkbox unchecked. I then have to check the enable checkbox,
"submit", "apply" and "save" in order to view my data. Note: this is
only a problem after restarting the server. How can I fix this issue?
John J. Mitchell
Which version of geoserver are you using so I can try and replicate the issue.
I haven't encountered this problem yet so it will take some experimenting.
Brent Owens
(The Open Planning Project)
John Mitchell wrote:
Brett,
I am using geoserver 1.3.3.
John Mitchell
issue.
Brent Owens
> Hi,
> Thanks,
John J. Mitchell
I have a setup where Geoserver is on different machine than postgres.....and
when both machines went down, the GS machine restarted first, and all the
datastores had the enabled box unchecked. Once I checked them and restarted
Tomcat, everything ran fine. I guess if GS and postgres are on the same
machine and GS restarts first, could that have the same effect?
Steve
Stephen Crawford
Center for Environmental Informatics
GeoVISTA Center
The Pennsylvania State University
814.865.9905
src176@anonymised.com
-----Original Message-----
From: geoserver-users-bounces@lists.sourceforge.net
[mailto:geoserver-users-bounces@lists.sourceforge.net] On Behalf Of John
Mitchell
Sent: Thursday, August 17, 2006 2:41 PM
To: Brent Owens
Subject: Re: [Geoserver-users] After I restart my server then an
existing"Postgis" datastore has the enable checkbox unchecked
Brett,
John Mitchell
the issue.
Brent Owens
> Hi,
> the enable checkbox unchecked. I then have to check the enable
> checkbox, "submit", "apply" and "save" in order to view my data.
> Note: this is only a problem after restarting the server. How can I fix
this issue?
> Thanks,
John J. Mitchell
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job
easier Download IBM WebSphere Application Server v.1.0.1 based on Apache
Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-users mailing list
Steve,
That is my suspision but it appears that geoserver as a default
installation does not have an entry within the listed services like
Postgres and Tomcat does. Because Postgres needs to come up before
Tomcat I have added a "new string value" within regedit for the Apache
Tomcat service which forces tomcat to wait until pgsql-8.0 has been
loaded. I would like to a similar thing with geoserver so that it
does not come up until postgres has been loaded.
John Mitchell
Steve
Stephen Crawford
GeoVISTA Center
814.865.9905
Mitchell
To: Brent Owens
Brett,
John Mitchell
> the issue.
> Brent Owens
> > Hi,
this issue?
> > Thanks,
John J. Mitchell
Geronimo
John J. Mitchell
FYI,
See: http://jira.codehaus.org/browse/GEOS-370 for a way to run
Geoserver as a service
Steve
Stephen Crawford
GeoVISTA Center
814.865.9905
Mitchell
To: Brent Owens
Brett,
John Mitchell
> the issue.
> Brent Owens
> > Hi,
this issue?
> > Thanks,
John J. Mitchell
Geronimo
John J. Mitchell
