[Geoserver-users] Alias on featureType?
Hello.
I'm getting an error when trying to adding a value to the "Alias" field
inte the feature type editor. Everything is ok when I press "Submit" and
"Apply", but when I try to save the following error code occurs:
The following exception was thrown:
      * class java.lang.NullPointerException:
Details:
  at org.vfny.geoserver.global.FeatureTypeInfo.getSrsHandling(FeatureTypeInfo.java:1742)
  at org.vfny.geoserver.global.FeatureTypeInfo.toDTO(FeatureTypeInfo.java:523)
  at org.vfny.geoserver.global.Data.toDTO(Data.java:1593)
  at org.vfny.geoserver.action.SaveXMLAction.saveGeoserver(SaveXMLAction.java:63)
  at org.vfny.geoserver.action.SaveXMLAction.execute(SaveXMLAction.java:45)
  at org.vfny.geoserver.action.ConfigAction.execute(ConfigAction.java:101)
  at org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:431)
  at org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:236)
  at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1196)
  at org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:432)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:710)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
  at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:269)
  at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:188)
  at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
  at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:215)
  at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
  at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
  at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
  at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
  at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
  at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
  at org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:142)
  at org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:81)
  at org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:217)
  at org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:106)
  at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
  at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
  at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
  at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
  at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:163)
  at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
  at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:210)
  at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:172)
  at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
  at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:117)
  at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:108)
  at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:151)
  at org.apache.jk.server.JkCoyoteHandler.invoke(JkCoyoteHandler.java:200)
  at org.apache.jk.common.HandlerRequest.invoke(HandlerRequest.java:283)
  at org.apache.jk.common.ChannelSocket.invoke(ChannelSocket.java:773)
  at org.apache.jk.common.ChannelSocket.processConnection(ChannelSocket.java:703)
  at org.apache.jk.common.ChannelSocket$SocketConnection.runIt(ChannelSocket.java:895)
  at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:685)
  at java.lang.Thread.run(Thread.java:619)
Hi Marten,
I believe this is a known issue:
http://jira.codehaus.org/browse/GEOS-2405
It has been fixed and will be pushed out with 1.7.1 (this week). However if you want the fix now you should be able to grab a recent nightly build.
http://gridlock.openplans.org/geoserver/1.7.x/
-Justin
Marten Andersson wrote:
Hello.
The following exception was thrown: * class java.lang.NullPointerException:
Details:
SF.Net email is Sponsored by MIX09, March 18-20, 2009 in Las Vegas, Nevada.
The future of the web can't happen without you. Join us at MIX09 to help
pave the way to the Next Web now. Learn more and register at
http://ad.doubleclick.net/clk;208669438;13503038;i?http://2009.visitmix.com/
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
