There is the international inch (25.4 mm) and the US Survey Inch (25.4000508
mm), which one is Geoserver actually internally considering an inch?
Our current scales that work correctly with the ESRI JavaScript API are
based on the US survey inch, whereas the scales that work correctly with
ArcMap are based on the international inch.
Puzzled.
Christian
____________________________
Dr Christian Maul
Project Manager
Information Services Branch
Department of Sustainability and Environment
Level13, Marland House, 570 Bourke Street
Melbourne 3000
public static final [Unit](http://jscience.org/jsr-275/api/javax/measure/unit/Unit.html)<[Length](http://jscience.org/jsr-275/api/javax/measure/quantity/Length.html)> **INCH**
A unit of length equal to `0.0254 m` (standard name `in`).
Still if you need to define more units you can, does the WKT or EPSG provide an EPSG code for the different units so we can tell them apart?
Jody Garnett
On Friday, 30 August 2013 at 1:23 PM, cmaul wrote:
Hello,
Puzzled.
Christian
Dr Christian Maul
Project Manager
Melbourne 3000
Learn the latest–Visual Studio 2012, SharePoint 2013, SQL 2012, more!
Discover the easy way to master current and previous Microsoft technologies
and advance your career. Get an incredible 1,500+ hours of step-by-step
tutorial videos with LearnDevNow. Subscribe today and save! http://pubads.g.doubleclick.net/gampad/clk?id=58040911&iu=/4140/ostg.clktrk
