Hi everybody,
we are trying to hatch our polygons using GraphicFill, but using
alternating pattern ( every other hatching row begins with some offset
- half of the distance between two GraphicFill objects)
We managed to do it but its kind hacky, using 2 PolygonSymbolizers and
graphic-margin vendor option to achieve the effect.
The problem is that when one changes dpi:300, hatch is of course not
aligned anymore (and we dont want to create one additional style per
dpi and adjust graphic-margin values)
Does anyone know if this is possible to do without using this ugly hack?
Thank you,
Ivan
<sld:Rule>
<sld:PolygonSymbolizer>
<sld:Fill>
<sld:GraphicFill>
<sld:Graphic>
<sld:Mark>
<sld:WellKnownName>ttf://symbol#44</sld:WellKnownName>
</sld:Mark>
<sld:Size>9</sld:Size>
</sld:Graphic>
</sld:GraphicFill>
</sld:Fill>
<sld:VendorOption name="graphic-margin">1 12 12 1</sld:VendorOption>
</sld:PolygonSymbolizer>
<sld:Fill>
<sld:GraphicFill>
<sld:Graphic>
<sld:Mark>
</sld:Mark>
</sld:Graphic>
</sld:GraphicFill>
</sld:Fill>
<sld:VendorOption name="graphic-margin">12 1 1 12</sld:VendorOption>
</sld:Rule>
Hi Ivan,
looking at it, it seems like s a bug in the style rescaler, it’s not rescaling the graphic-margin for polygon fills.
Checked the code, graphic-margin it’s indeed rescaled for text-symbolizer, but not for polygon symbolizer.
On Wed, Jun 8, 2016 at 11:22 AM, Ivan Grcic <ivan.grcic@anonymised.com> wrote:
Hi everybody,
Thank you,
Ivan
sld:Rule
sld:Fill
sld:GraphicFill
sld:Graphic
sld:Mark
sld:WellKnownNamettf://symbol#44</sld:WellKnownName>
</sld:Mark>
sld:Size9</sld:Size>
</sld:Graphic>
</sld:GraphicFill>
</sld:Fill>
<sld:VendorOption name=“graphic-margin”>1 12 12 1</sld:VendorOption>
sld:Fill
sld:GraphicFill
sld:Graphic
sld:Mark
</sld:Mark>
</sld:Graphic>
</sld:GraphicFill>
</sld:Fill>
<sld:VendorOption name=“graphic-margin”>12 1 1 12</sld:VendorOption>
</sld:Rule>
What NetFlow Analyzer can do for you? Monitors network bandwidth and traffic
patterns at an interface-level. Reveals which users, apps, and protocols are
consuming the most bandwidth. Provides multi-vendor support for NetFlow,
J-Flow, sFlow and other flows. Make informed decisions using capacity
planning reports. https://ad.doubleclick.net/ddm/clk/305295220;132659582;e
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
