Hi!
A would like to use animation. The ouput fotmat is Image/gif. But the gif is not transparent. Can anybody help me?
Thank’s
Endre
Hi!
Thank’s
Endre
Hi Endre,
Could you be a bit clearer. What gif isn’t transparent? Input or output?
Although I see no reference to transparency - http://docs.geoserver.org/stable/en/user/tutorials/animreflector.html - so don’t know if it’s supported. Maybe someone else on the list knows.
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
On 24 February 2014 08:36, Holb Endre <holb.endre@anonymised.com> wrote:
Hi!
Thank’s
Endre
Flow-based real-time traffic analytics software. Cisco certified tool.
Monitor traffic, SLAs, QoS, Medianet, WAAS etc. with NetFlow Analyzer
Customize your own dashboards, set traffic alerts and generate reports.
Network behavioral analysis & security monitoring. All-in-one tool.
http://pubads.g.doubleclick.net/gampad/clk?id=126839071&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Ciao,
GIF animated can be transparent if the images they are composed by are transparent.
GIF supports the so called bitmask transparency, so images are either transparent or opaque.
Translucency is not supported.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
On Mon, Feb 24, 2014 at 6:38 PM, Jonathan Moules <jonathanmoules@anonymised.com> wrote:
Hi Endre,
JonathanThis transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
Hi!
Thank’s
Endre
