I'm trying to load an antarctic polar stereographic image, stored as a
geotiff, into geoserver as a coverage store but failing with the message,
'bad ordinates at dimension 0'.
The error may be because I have mis-formed the geotiff or it may be that
geoserver can't load a coverage in this format.
Has anyone successfully loaded data of this type? If so, do they have an
example geotiff I can examine or can they offer any advice.
Ciao Dave,
can you make available to me the geotiff for testing? Moreover, which
version of geoserver are you using?
Simone.
On Thu, Sep 25, 2008 at 12:24 PM, djud <djud@anonymised.com> wrote:
Hello,
This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
Build the coolest Linux based applications with Moblin SDK & win great prizes
Grand prize is a trip for two to an Open Source event anywhere in the world http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geoserver-users mailing list
Geoserver-users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-users
GeoServer definitely can do Geotiff. One good way to debug a problem with your image is to use the command line utility gdalinfo (not sure if you are familiar with it).
If gdal can load and produce information about the file then the problem is likely in GeoServer. If not it is likely a problem with the file.
-Justin
djud wrote:
Hello,
Thank you,
Dave
Justin Deoliveira
OpenGeo - http://opengeo.org
