[Geoserver-users] Antw: Inserting Features with WFS-T (INSERT) into Oracle
Hi Gregor,
Ronald Woita
http://geoportal.rostock.de
Hansestadt Rostock
Kataster-, Vermessungs- und Liegenschaftsamt
Holbeinplatz 14, 18069 Rostock
email: ronald.woita@anonymised.com
phone: +49 (0)381 - 381 6256
Gregor Fikoczek <gregor.fikoczek@anonymised.com> 08.08.2007 13:16 >>>
=> Filled the USER_SDO_GEOM_METADATA with SRID =4326
=> Created an Spatial Index with PARAMETERS ('SDO_INDX_DIMS=2
LAYER_GTYPE=POINT')
=> PrimaryKey on a NUMBER Column
ORA-13365: Layer-SRID does not correspond to the Geometry-SRID
ORA-06512: in "MDSYS.SDO_INDEX_METHOD_9I", line 210
ORA-06512: in line 1
the issue is that you fill the USER_SDO_GEOM_METADATA with SRID=4326.
GeoServer inserts SRID=NULL with the Geometry, so that LayerSRID does'nt correspond with GeometrySRID.
An example for a wfs:insert with GeoServer-1.5.2 (the first NULL is the value for SDO_SRID)
SDO_GEOMETRY(2007, NULL, NULL, SDO_ELEM_INFO_ARRAY(1, 1003, 1), SDO_ORDINATE_ARR
AY(4505580, 5994620, 4505830, 5993590, 4506730, 5994500, 4506190, 5995160, 45055
80, 5994620))
regards
Ronald
Ronald Woita ha scritto:
Hi Gregor,
Ronald Woita
Hansestadt Rostock
email: ronald.woita@anonymised.com phone: +49 (0)381 - 381 6256
=> Created an Spatial Index with PARAMETERS ('SDO_INDX_DIMS=2 LAYER_GTYPE=POINT')
80, 5994620))
Sorry? I thought I had this fixed in 1.5.2. If you specify the SRID in
the geom metadata, 1.5.2 should perform the insert without issues.
Gregor, can you try out 1.5.2 and report back?
Hi, Ronald, hi Andrea,
@Ronald: thxs for the information.
Hi Gregor,
Ronald Woita
Hansestadt Rostock
Gregor Fikoczek gregor.fikoczek@anonymised.com 08.08.2007 13:16 >>>
=> Created an Spatial Index with PARAMETERS (‘SDO_INDX_DIMS=2 LAYER_GTYPE=POINT’)
ORA-06512: in “MDSYS.SDO_INDEX_METHOD_9I”, line 210
GeoServer inserts SRID=NULL with the Geometry, so that LayerSRID does’nt correspond with GeometrySRID.
80, 5994620))
@Andrea: Thanks for the quick answer.
I tested the INSERT-Request with the new geoserver 1.5.2. and
it works :slight_smile: !!!
Well done :wink:
<wfs:WFS_TransactionResponse version=“1.0.0” xsi:schemaLocation=“http://www.opengis.net/wfs http://localhost:8080/geoserver/schemas/wfs/1.0.0/WFS-transaction.xsd”>
<wfs:InsertResult handle=“null TEST_POINT 1”>
<ogc:FeatureId fid=“TEST_POINT.3”/>
</wfs:InsertResult>
wfs:TransactionResult
wfs:Status
wfs:SUCCESS/
</wfs:Status>
</wfs:TransactionResult>
</wfs:WFS_TransactionResponse>
Gregor
WhereGroup GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Fon: +49 (0)228 / 90 90 38 - 25
Fax: +49 (0)228 / 90 90 38 - 11
Dipl. Ing. (FH) Gregor Fikoczek
[mailto:gregor.fikoczek@anonymised.com](mailto:gregor.fikoczek@anonymised.com)
[mailto:info@anonymised.com](mailto:info@anonymised.com)
[http://www.wheregroup.com](http://www.wheregroup.com)
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRA 6788
Well done :wink:
Good! :slight_smile:
