I am using the built from 07/31/07 and the kmlPlacemarkDescription.ftl is located in the featuretype datadir.
Ronald
Ronald Woita
http://geoportal.rostock.de
Hansestadt Rostock
Kataster-, Vermessungs- und Liegenschaftsamt
Holbeinplatz 14, 18069 Rostock
email: ronald.woita@anonymised.com
phone: +49 (0)381 - 381 6256
Andrea Aime <aaime@anonymised.com> 02.08.2007 14:16 >>>
Ronald Woita ha scritto:
Hi Andrea,
I tested the latest nightly built (geoserver-1.5.x-080107.war) and the kml-Output is correct
And then I just found a misconfiguration in my GeoServer-1.6 setup, so that the external Graphic is picking up correctly from SLD in this version too.
But it seems, that the GeoServer-1.6beta beyond ignores my template . . .
Have you tried a recent nightly too? http://geo.openplans.org/nightly/trunk/
Btw, where are you putting your template files?
Ahhh... I think i know what is going on.. The first cut of kml templates used kmlPlacemarkDesciption.ftl as the name of the template. However it was then changes to just description.ftl to be used for other formats... Try changing the name of the file and see if that helps.
Are the docs still referencing kmlPlacemarkDescription.ftl? Also I thought that both were accepted for backwards compatibility reasons... I Will have to check into that.
-Justin
Ronald
Ronald Woita
Hansestadt Rostock
email: ronald.woita@anonymised.com phone: +49 (0)381 - 381 6256
Hi Andrea,
Geoserver-users mailing list
!DSPAM:4007,46b1ceb755492085621377!
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
