I'm tagging Chris into this conversation since he knows the most about Oracle, and this appears to be a problem with your Oracle.
Chris: Basically when he uses a WFS request against his shapefile feature types, it works, but when he does the same request against his Oracle feature type he gets the error.
Brent Owens
(The Open Planning Project)
Dirk Buechel wrote:
Dear Brent,
I'm using the WFS request.
With shapefiles it works fine (like in the wfs-t_demo) and I'm getting the requested feature infos!My oracle table has got a geometry column, a spatial index and a primary key (as told to be necessary in the docs).
I defined with the WebAdminTool a new namespace, a new datastore (to the oracle-user) and the featuretype to the oracle table.
Then I adjusted the config.xml (I sent you the file yesterday) to request the feature infos of the oracle data with "wfsGetFeatureInfo".
And now when I click in the map after choosing the GetFeatureInfo-Button I got the errors I recently sent to you.cheers
Dirk
Dirk Büchel
MAIRDUMONT
Marco-Polo-Str. 1
73760 Ostfildern (Kemnat)Telefon: + 49 711 45 02-1056
Telefax: + 49 711 45 02-320d.buechel@anonymised.com
www.mairdumont.com*Brent Owens <brentowens@anonymised.com>*
22.08.2006 17:33
An
Dirk Buechel <d.buechel@anonymised.com>
Kopie
Thema
Re: Antwort: Re: Antwort: Re: [Geoserver-users] wfsGetFeature-ProblemThe wfs-t demo should work 'out of the box', and if it isn't, something
weird is going on.
Is that what you are using to test the WFS request? Or are you using
some other client tool?Have you tried any of the other datasets (ones that come with geoserver
that aren't in Oracle)?If other datasets are working, it will be a problem with Oracle and how
your table is set up. If you have a geometry column and whatnot. We will
have to look into that issue in more depth.Brent Owens
(The Open Planning Project)Dirk Buechel wrote:
> Hi Brent,
> another question is: why does the wfs-t_demo with the config.xml and
> the "wfsGetFeature" entry is going well? What's wrong in my config.xml
> definition?
> cheers,
> Dirk
> Dirk Büchel
> MAIRDUMONT
> Marco-Polo-Str. 1
> www.mairdumont.com
> 21.08.2006 19:28
> > An
> Kopie
> > Thema
> Hi Dirk
> Are you trying to do a GetFeatureInfo request, a GetFeature request, or
> a WMS GetMap request?
> The request you sent me is a GetMap request, part of WMS not WFS. So are
> you expecting to get back an image, or GML?
> cheers,
> Brent Owens
> Dirk Buechel wrote:
> > Hello Brent,
> > first of all, thank you very much for supporting me.
> > Sorry, but at the moment I'm a real newbie to geoserver.
> > I' m sending you my config.xml attached. Perhaps you can figure out
> > something wrong...(WFS-definitions?)
> > The target of the "wfsGetFeature" is the mainMap -> so the request is:
> http://localhost/geoserver/wms?VERSION=1.1.1&REQUEST=GetMap&SERVICE=WMS&SRS=EPSG:4326&BBOX=11.100000000000001,48.48273333333333,11.32,48.666066666666666&WIDTH=600&HEIGHT=500&LAYERS=NT18:PUBLICTRAFFIC&FORMAT=image/png&STYLES=&TRANSPARENT=TRUE&UNIQUEID=>
> > Please let me know if I should send you further informations.
> > Dirk
> > 21.08.2006 17:15
> > > > An
> > Kopie
> > geoserver-users@lists.sourceforge.net
> > Thema
> > Hi Dirk,
> > Could you show us the request you are using? We can help find the
> > problem then.
> > From that error it looks like you aren't passing in any constraints,
> > and that is causing it to barf.
> > Brent Owens
> > Dirk Buechel wrote:
> > > Hello!
> > > I've just got a problem concerning "wfsGetFeature"-Request in
> > > Geoserver 1.3.3.
> > > When I'm trying to request the Feature Infos from an
> > > Oracle-FeatureType (PUBLICTRAFFIC) I'm getting the following error
> > > message:
> > > javax.xml.transform.TransformerException: Translator error
> > > I've got a primary Key-Constraint and a spatial Index defined for the
> > > oracle table PUBLICTRAFFIC (feature class).
> > > The LOG-File tells me:
> > > 21.08.2006 12:32:28 org.geotools.data.jdbc.JDBC1DataStore executeQuery
> > > SCHWERWIEGEND: Error Performing SQL query: SELECT "PK_PTRAFFIC",
> > > "PUBTRAF_ID", "COUNTRY_ID", "CAT_ID", "NETWORK_ID", "DIR_ID",
> > > "FLOOR_ID", "CONST_ID", "FOREIGN_ID", "FOREIGNKEY", "MODDATE_A",
> > > "MODOPER_A", "MODDATE_G", "MODOPER_G", "CREATEDATE", "CREATEOPER",
> > > "GEOM" FROM "PUBLICTRAFFIC" WHERE
> > > java.sql.SQLException: ORA-00921: unexpected end of SQL command
> > > at
> oracle.jdbc.driver.DatabaseError.throwSqlException(DatabaseError.java:125)>
> > > at
> > > oracle.jdbc.driver.T2CConnection.checkError(T2CConnection.java:681)
> > > at
> > > oracle.jdbc.driver.T2CConnection.checkError(T2CConnection.java:614)
> > > at
> oracle.jdbc.driver.T2CStatement.execute_for_describe(T2CStatement.java:841)>
> > > at
> oracle.jdbc.driver.OracleStatement.execute_maybe_describe(OracleStatement.java:942)>
> > > at
> oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(OracleStatement.java:1037)>
> > > at
> oracle.jdbc.driver.OracleStatement.executeQuery(OracleStatement.java:1183)>
> > > at
> org.geotools.data.jdbc.JDBC1DataStore.executeQuery(JDBC1DataStore.java:897)>
> > > at
> org.geotools.data.jdbc.JDBC1DataStore.getFeatureReader(JDBC1DataStore.java:656)>
> > > at
> org.geotools.data.jdbc.JDBCFeatureCollection.reader(JDBCFeatureCollection.java:78)>
> > > at
> org.geotools.data.DefaultFeatureResults.getBounds(DefaultFeatureResults.java:193)>
> > > at
> org.geotools.gml.producer.FeatureTransformer$FeatureTranslator.encode(FeatureTransformer.java:389)>
> > > at
> org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:611)>
> > > at
> org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:463)>
> > > at
> org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:293)>
> > > at
> org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:126)>
> > > at
> org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:105)>
> > > at
> org.vfny.geoserver.wfs.responses.GML2FeatureResponseDelegate.encode(GML2FeatureResponseDelegate.java:225)>
> > > at
> org.vfny.geoserver.wfs.responses.FeatureResponse.writeTo(FeatureResponse.java:141)>
> > > at
> org.vfny.geoserver.servlets.AbstractService.doService(AbstractService.java:527)>
> > > at
> org.vfny.geoserver.servlets.AbstractService.doGet(AbstractService.java:279)>
> > > at
> org.vfny.geoserver.wfs.servlets.WfsDispatcher.doResponse(WfsDispatcher.java:284)>
> > > at
> org.vfny.geoserver.wfs.servlets.WfsDispatcher.doGet(WfsDispatcher.java:213)>
> > > at
> javax.servlet.http.HttpServlet.service(HttpServlet.java:740)
> > > at
> javax.servlet.http.HttpServlet.service(HttpServlet.java:853)
> > > at
> > > org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:358)
> > > at
> org.mortbay.jetty.servlet.WebApplicationHandler$Chain.doFilter(WebApplicationHandler.java:342)>
> > > at
> org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:122)>
> > > at
> org.mortbay.jetty.servlet.WebApplicationHandler$Chain.doFilter(WebApplicationHandler.java:334)>
> > > at
> org.mortbay.jetty.servlet.WebApplicationHandler.dispatch(WebApplicationHandler.java:286)>
> > > at
> org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:567)
> > > at org.mortbay.http.HttpContext.handle(HttpContext.java:1807)
> > > at
> org.mortbay.jetty.servlet.WebApplicationContext.handle(WebApplicationContext.java:525)>
> > > at org.mortbay.http.HttpContext.handle(HttpContext.java:1757)
> > > at org.mortbay.http.HttpServer.service(HttpServer.java:879)
> > > at
> > > org.mortbay.http.HttpConnection.service(HttpConnection.java:790)
> > > at
> > > org.mortbay.http.HttpConnection.handleNext(HttpConnection.java:961)
> > > at
> > > org.mortbay.http.HttpConnection.handle(HttpConnection.java:807)
> > > at
> org.mortbay.http.SocketListener.handleConnection(SocketListener.java:197)
> > > at
> > > org.mortbay.util.ThreadedServer.handle(ThreadedServer.java:276)
> > > at
> > > org.mortbay.util.ThreadPool$PoolThread.run(ThreadPool.java:511)
> > > I ask myself where is the WHERE-clause?
> > > Did I configure something wrong or missed a definition in the
> > config.xml?
> > > Did I forgot something in defining the FeatureType?
> > > A request like
> http://localhost/geoserver/wfs?request=GetFeature&version=1.0.0&propertyname=*&featureversion=1&typename=NT18:PUBLICTRAFFIC&featureid=PUBLICTRAFFIC.1515>
> > > works great!
> > > Thanks in advance for any help!
> > > Best regards,
> > > Dirk
> > > Using Tomcat but need to do more? Need to support web services,
> > security?
> > > Get stuff done quickly with pre-integrated technology to make your
> > job easier
> > > Download IBM WebSphere Application Server v.1.0.1 based on Apache
> > Geronimo
> http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
> > > _______________________________________________
> > > Geoserver-users mailing list
> > > Geoserver-users@lists.sourceforge.net
> > > https://lists.sourceforge.net/lists/listinfo/geoserver-users
