I almost had success with the OGR datastore with Geoserver 23 nightly and GDAL 3.8.0-dev on Windows. Installation does not quite succeed by reading the documentation https://docs.geoserver.org/latest/en/user/community/ogr-store/index.html but I can make a PR for updating the instructions if I manage to make everything work.
As a test I created an OGR datastore from geopackage and I can see all the tables. However, publishing the datastore fails with this error:
Native library load failed.
java.lang.UnsatisfiedLinkError: no osrjni in java.library.path:
I do not know where to search for “osrjni”.
-Jukka Rahkonen-
Lähettäjä: Andrea Aime <andrea.aime@…10949…>
Lähetetty: maanantai 2. lokakuuta 2023 21.00
Vastaanottaja: Rahkonen Jukka <jukka.rahkonen@…6847…>
Kopio: GeoServer Users geoserver-users@lists.sourceforge.net
Aihe: Re: [Geoserver-users] Anybody working on OGC API Features datastore?
If you need it now, there is the ogr datastore community module. It supports any OGR format,
so you should be able to use the OGC API Features reader
On Mon, Oct 2, 2023 at 3:53 PM Rahkonen Jukka <jukka.rahkonen@…6847…> wrote:
In a couple of years old blog post http://geotoolsnews.blogspot.com/2020/09/ there is a wish for potential developers:
“We invite developers to contribute to the following work-in-progress:
- A new DataStore to access ogc-api features
Has anybody started to develop that datastore?
-Jukka Rahkonen-
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
