[Geoserver-users] AnyIntereacts - Filter 2.0
Hi list,
I am very thankful WFS 2.0 and Filter 2.0 have been implemented. I’m studying their capabilities and have 2 questions:
1 - I see in the the WFS 2.0 capabilities document that for temporal operators AnyInteracts is not listed. According to the Filter 2.0 specification the definition is as follows:
Applicable to TM_Period only, the temporal operator fes:AnyInteracts is a shortcut operator semantically equivalent to NOT (Before OR Meets OR MetBy OR After).
Because all the necessary operators (NOT, OR, Before, Meets, MetBy, After) are supported, I assume it should be a straightforward matter to simulate AnyInteracts by using these operators when composing the filter, right? Could someone please assert this? Would there be any disadvantages or limitations?
2 - I once used WFS 1.1 of Geoserver in a project and the filter then worked really well. To me it was almost like a fully functional mapping to the SQL conditions without limitations. Does filter 2.0 have any limitations compared with its 1.1 counterpart before?
Thank you very much!
Nhan
On Thu, Feb 14, 2013 at 10:57 AM, Nhan Vo <nhanvo@anonymised.com> wrote:
Hi list,
Hmm… not sure, but I had a quick look into the SQL encoder and indeed this particular temporal filter
does not seem to be supported.
May well just be an oversight. Justin (cc’ed) implemented temporal filter support, he probably knows more.
No, all WFS versions end up being summarized into the same object model, so a filter is encoded into SQL for WFS 1.1 will be
encoded into SQL also for WFS 2.0
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
On Sat, Feb 16, 2013 at 4:15 AM, Andrea Aime
Hi list,
I am very thankful WFS 2.0 and Filter 2.0 have been implemented. I'm
operators *AnyInteracts *is not listed. According to the Filter 2.0
*Applicable to TM_Period only, the temporal operator fes:AnyInteracts is
MetBy OR After).*
simulate *AnyInteracts *by using these operators when composing the
Hmm.. not sure, but I had a quick look into the SQL encoder and indeed
May well just be an oversight. Justin (cc'ed) implemented temporal filter
Yeah, looks like an oversight. The filter class exists and is implemented
as per the spec but its not listed in the caps doc (which
happens statically) and not handled natively by any datastores.
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Justin Deoliveira
OpenGeo - http://opengeo.org
