[Geoserver-users] Apache proxy pass to gwc
Hello again everyone,
i wanted to see if the group has ideas on configuring GeoWebCache when handling a connection from a apache proxy pass. We want to use one install of the geoserver on a non-public port with several webheads passing a connection to it.
It would look something like:
http://webhead1.mysite.com/gmaps → http://geoserver.mysite.com:123456/geoserver/gwc/service/gmaps
http://webhead2.mysite.com/gmaps → http://geoserver.mysite.com:123456/geoserver/gwc/service/gmaps
What configurations, if any are needed on the geoserver to accommodate this setup.
Thanks everyone.
Brian Youngblood
Online Technical Lead
Southern Poverty Law Center
334.956.8332
I don't really see the question. Have you tried, is there a problem?
Should work like any proxy, same idea as http://geoserver.org/display/GEOSDOC/How+to+proxy+Jetty+through+Apache+on+port+80
I recommend you turn off Apache logging, else you'll take a bit I/O hit on your webheads.
-Arne
http://webhead1.mysite.com/gmaps --> http://geoserver.mysite.com:123456/geoserver/gwc/service/gmaps
http://webhead2.mysite.com/gmaps --> http://geoserver.mysite.com:123456/geoserver/gwc/service/gmaps
Thanks everyone.
*Brian Youngblood**
*Online Technical Lead
*Southern Poverty Law Center**
*334.956.8332
Arne Kepp
OpenGeo - http://opengeo.org
Expert service straight from the developers
Hi Arne,
yeah, it's working. I just wanted to see if there was a absolute path coded somewhere in the geoserver configuration that needed changing. Thanks for mentioning the logging. I'll look into excluding these from our log.
Take care,
Brian Youngblood
-Arne
Thanks everyone.
*Brian Youngblood**
Arne Kepp
