[Geoserver-users] Apache Tomcat crashing...
  1. What version of Java are you running?
    vm_info: Java HotSpot™ Server VM (1.6.0_03-b05) for linux-x86, built on Sep 24 2007 22:32:39 by “java_re” with gcc 3.2.1-7a (J2SE release)
  1. How much physical memory does the machine actually have?
    8 gigs
Try setting
both Xms and Xmx to 512
Done.
  1. Alternatively, move GeoServer to it’s own application
    server (can be
    on the same machine), see what eats memory.
    Will discuss it with the admin…
Thanks so far!
Stefan
-Arne
Ziegler Stefan wrote:
Hi
after running Apache Tomcat for a whole month without problems, it
crashes now too often (after approx. 2 days). The error I get:
“java.lang.OutOfMemoryError: requested 140 bytes for
CHeapObj-new. Out
of swap space?”
My JVM options:
export MALLOC_CHECK_=0
JAVA_OPTS=“-Djava.awt.headless=true”
JAVA_OPTS=“$JAVA_OPTS -server "
JAVA_OPTS=”$JAVA_OPTS -XX:SoftRefLRUPolicyMSPerMB=36000 "
JAVA_OPTS=“$JAVA_OPTS -Xms128m -Xmx768m "
JAVA_OPTS=”$JAVA_OPTS -XX:PermSize=128m "
JAVA_OPTS="$JAVA_OPTS -XX:MaxPermSize=256m "
Is there a way to find out which process makes Tomcat crashing? (I
have two other servlets running in Tomcat) And how to avoid
crashing
Tomcat this often? [GeoServer 1.6.4b, Apache Tomcat 5.5.25 on a Red
Hat Enterprise Linux ES release 4 (Nahant Update 6)]
regards
Stefan
Mit freundlichem Gruss
Stefan Ziegler
Leiter Aufsicht
Kanton Solothurn
Bau- und Justizdepartement
Amt für Geoinformation
Rötistrasse 4
4501 Solothurn
Telefon 032 627 75 96
Telefax 032 627 75 98
stefan.ziegler@anonymised.com
http://www.so.ch
This SF.Net email is sponsored by the Moblin Your Move
Developer’s challenge
Build the coolest Linux based applications with Moblin SDK
& win great prizes
Grand prize is a trip for two to an Open Source event
anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geoserver-users mailing list
Yeah, our setup is pretty similar, except I use Tomcat 6.x, so that sounds good. Java 6 lets you use tools like visualvm remotely, so that simplifies things a bit.
I would probably increase Xms and Xmx to at least 1024 Mb (unless you really need it for other applications). Rendering big WMS images with 32 bit color depth is not cheap, but people run GeoServer with much less.
-Arne
> 1) What version of Java are you running?
vm_info: Java HotSpot(TM) Server VM (1.6.0_03-b05) for linux-x86, built on Sep 24 2007 22:32:39 by "java_re" with gcc 3.2.1-7a (J2SE release)
> 2) How much physical memory does the machine actually have?
8 gigs
> Try setting
Done.
> 3) Alternatively, move GeoServer to it's own application
> server (can be
Will discuss it with the admin...
Thanks so far!
Stefan
> -Arne
> > Hi
> > "java.lang.OutOfMemoryError: requested 140 bytes for
> CHeapObj-new. Out
> > of swap space?"
> > My JVM options:
> > JAVA_OPTS="-Djava.awt.headless=true"
> > JAVA_OPTS="$JAVA_OPTS -server "
> > JAVA_OPTS="$JAVA_OPTS -XX:SoftRefLRUPolicyMSPerMB=36000 "
> > JAVA_OPTS="$JAVA_OPTS -Xms128m -Xmx768m "
> > JAVA_OPTS="$JAVA_OPTS -XX:PermSize=128m "
> crashing
> > regards
> > Stefan
> > Stefan Ziegler
> > Leiter Aufsicht
> > Kanton Solothurn
> > Rötistrasse 4
> > 4501 Solothurn
> > http://www.so.ch
> Developer's challenge
> & win great prizes
> > _______________________________________________
> > Geoserver-users@lists.sourceforge.net
> > https://lists.sourceforge.net/lists/listinfo/geoserver-users
