[Geoserver-users] app-schema and a mapping to generate xlink:href or xsi:nil on the same element
Below is a write-up of a problem I’ve encountered using app-schemas when specifying a mapping for an element whose attributes should be chosen dynamically. I’m also posting a solution that works for me. I would like to ask if anyone knows a simpler way to archive the same. Please let me know if I should include more information.
Kind Regards,
Lazar
Geoserver 2.4.4 App-Schema Mapping
Questions
  1. What is the simplest way to generate an element that should sometimes have an xlink:href attribute and sometimes have an xsi:nil attribute, where the choice is data-driven?
  2. As a last resort, is fiddling with geoserver’s private cache of XSD files an accepted technique for coercing it to produce required output?
Problem and workaround involving xlink:href and xsi:nil
Requirement
Generate
<gsmlga:eventProcess xsi:nil=“true” nilReason=“missing”>
or
<gsmlga:eventProcess xlink:href=“http://resource.geoscience.gov.au/classifier/ga/eventprocess/deposition” xlink:title=“deposition”>
Solution
App-schema mapping
gsml:relatedFeature/gsmlga:GeologicHistory/gsml:relatedFeature/gsmlga:GeologicEvent/gsmlga:eventProcess xlink:href EVENTPROCESS_URI xlink:title EVENTPROCESS gsml:relatedFeature/gsmlga:GeologicHistory/gsml:relatedFeature/gsmlga:GeologicEvent/gsmlga:eventProcess true xsi:nil if_then_else(isNull(EVENTPROCESS_URI), 'true', Expression.NIL) nilReason if_then_else(isNull(EVENTPROCESS_URI), 'missing', Expression.NIL)
Target element is gsmlgu:GeologicUnit. The schemas are
xmlns:gml=“http://www.opengis.net/gml/3.2
xmlns:gsml=“http://xmlns.geosciml.org/GeoSciML-Core/3.2
xmlns:gsmlga=“http://xmlns.geosciml.org/GeologicAge/3.2
The above mapping works when EVENTPROCESS_URI is not null, but otherwise, it generates
<gsmlga:eventProcess xlink:href=“#null” xsi:nil=“true” nilReason=“missing”/>
In fact, even the following mapping
generates
<gsmlga:eventProcess xlink:href=“#null”/>
Since the above mapping is so minimal, I think that geoserver decides to insert the xlink:href attribute based on something it sees in the definition of eventProcess (where else?
it’s not the mapping and it’s not the data). Here is the definition from geologicAge.xsd
gsmlga:EventProcessTerm The eventProcess specifies the process or processes that occurred during the event. Examples include deposition, extrusion, intrusion, cooling.
Drilling further into the types, however, shows that xlink:href is not a required attribute.
When I change this definition, in my app-schema-cache, to
gml:targetElementgsmlga:EventProcessTerm</gml:targetElement>
the mapping works as required. Now that eventProcess can be of any type, geoserver cannot infer that it should insert a null xlink:href attribute into the generated element. Why does it in the first place?
Note
The problem goes away if the requirements are changed to generate
<gsmlga:eventProcess xlink:href=“http://www.opengis.net/def/nil/OGC/0/missing” xlink:title=“missing”/>
or
and not use xsi:nil attribute at all. The mapping becomes straightforward.
Kind Regards,
Lazar
This is a bug in ReferenceTypeBinding (the type for eventProcess). I have
submitted a fix in https://jira.codehaus.org/browse/GEOT-4757.
Rini
View this message in context: http://osgeo-org.1560.x6.nabble.com/app-schema-and-a-mapping-to-generate-xlink-href-or-xsi-nil-on-the-same-element-tp5132993p5133068.html
