[Geoserver-users] App-schema and CharacterString Type
Hello All,
I am trying to use the following constructs from the GMD namespace: CI_Contact / CI_Telephone + CI_Address
It uses the ‘CharacterString_PropertyType’ which when i look at:
http://www.isotc211.org/2005/gco/basicTypes.xsd
States:
<xs:element name="CharacterString" type="xs:string"/>
<xs:complexType name="CharacterString_PropertyType">
	<xs:sequence minOccurs="0">
		<xs:element ref="gco:CharacterString"/>
	</xs:sequence>
	<xs:attribute ref="gco:nilReason"/>
</xs:complexType>
So it appears it maps back to the general ‘string’ type, but it is not working when trying to populate the entry with a varchar from the DB.
Ideas? (Below is trace output from geoserver.log)
2013-10-11 11:11:11,192 TRACE [org.geotools.data.complex.filter] - ENTRY FeatureImpl:CI_Address<CI_Address_Type id=2>= gmd:city next city null null
2013-10-11 11:11:11,192 TRACE [org.geotools.data.complex.filter] - ENTRY FeatureImpl:CI_Address<CI_Address_Type id=2>=[ComplexAttributeImpl:city<CharacterString_PropertyType>=] gmd:postalCode null null null
Thanks in advance
Please provide your mapping file and a description of the problem (empty or missing element)?
Kind regards,
Ben.
On 11/10/13 08:58, snuffy wrote:
Hello All,
It uses the 'CharacterString_PropertyType' which when i look at:
States:
  </xs:sequence>
</xs:complexType>
So it appears it maps back to the general 'string' type, but it is not
Thanks in advance
October Webinars: Code for Performance
Free Intel webinars can help you accelerate application performance.
Explore tips for MPI, OpenMP, advanced profiling, and more. Get the most from
the latest Intel processors and coprocessors. See abstracts and register >
http://pubads.g.doubleclick.net/gampad/clk?id=60134071&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
Hello Ben,
I think my issue was I read it wrongly,
So CI_Contact and friends use ‘gco:CharacterString’ as their types which in turn is a string…
eg: http://www.schemacentral.com/sc/niem21/e-gmd_phone-1.html
Using a mapping like the following then worked correctly:
gmd:electronicMailAddress/gco:CharacterString fcon_email
The mapping below failed because it was expecting a ‘gco:CharacterString’ entry not a string.
gmd:electronicMailAddress fcon_email
On 14 October 2013 14:33, Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com> wrote:
Kind regards,
Ben.
Hello All,
States:
<xs:element name=“CharacterString” type=“xs:string”/>
<xs:complexType name=“CharacterString_PropertyType”>
<xs:sequence minOccurs=“0”>
<xs:element ref=“gco:CharacterString”/>
</xs:sequence>
<xs:attribute ref=“gco:nilReason”/>
</xs:complexType>
Thanks in advance
Geoserver-users@anonymised.comsourceforge.net
Ben Caradoc-Davies Ben.Caradoc-Davies@anonymised.com
Software Engineer
As a minor follow up to this.
I’ve tried taking my ‘company’ schema and adding a CI_Contact entry.
I believe something is not right in my xsd/xml.
The error is listed below:
ows:ExceptionText
java.lang.RuntimeException: Error applying mapping with targetAttribute company:contactInfo Error applying mapping with targetAttribute company:contactInfo java.io.IOException null Schema ‘person’ does not exist.
Have attached zip with relevant files.
company-app-schema.zip (385 KB)
On 14 October 2013 17:14, snuffy <snuffy22@anonymised.com> wrote:
Hello Ben,
Kind regards,
Ben.
Hello All,
States:
</xs:sequence>
</xs:complexType>
Thanks in advance
Software Engineer
I was also surprised by the use of string as the simple content of a complex property in this way; this encoding style differs from the use of gml:MeasureType and gml:CodeType. Good to hear you got it working.
Kind regards,
Ben.
On 14/10/13 14:14, snuffy wrote:
Hello Ben,
So CI_Contact and friends use 'gco:CharacterString' as their types
which in turn is a string..
         <AttributeMapping>
<targetAttribute>gmd:electronicMailAddress/gco:CharacterString</targetAttribute>
           <sourceExpression>
             <OCQL>fcon_email</OCQL>
           </sourceExpression>
         </AttributeMapping>
'gco:CharacterString' entry not a string.
         <AttributeMapping>
           <targetAttribute>gmd:electronicMailAddress</targetAttribute>
           <sourceExpression>
           </sourceExpression>
         </AttributeMapping>
<Ben.Caradoc-Davies@anonymised.com <mailto:Ben.Caradoc-Davies@anonymised.com>> wrote:
    Kind regards,
    Ben.
        Hello All,
        http://www.isotc211.org/2005/__gco/basicTypes.xsd
        <http://www.isotc211.org/2005/gco/basicTypes.xsd&gt;
        States:
        <xs:complexType name="CharacterString___PropertyType">
                 </xs:sequence>
        </xs:complexType>
        is not
        the DB.
        [org.geotools.data.complex.__filter] - ENTRY
        FeatureImpl:CI_Address<CI___Address_Type id=2>= gmd:city next
        city null null
        id=2>=[ComplexAttributeImpl:__city<CharacterString___PropertyType>=]
        Thanks in advance
        ------------------------------__------------------------------__------------------
        the most from
        register >
        http://pubads.g.doubleclick.__net/gampad/clk?id=60134071&iu=__/4140/ostg.clktrk
        <http://pubads.g.doubleclick.net/gampad/clk?id=60134071&iu=/4140/ostg.clktrk&gt;
        _________________________________________________
        <mailto:Geoserver-users@lists.sourceforge.net>
        https://lists.sourceforge.net/__lists/listinfo/geoserver-users
        <https://lists.sourceforge.net/lists/listinfo/geoserver-users&gt;
    Software Engineer
Software Engineer
Do you have a full stack trace?
I've tried taking my 'company' schema and adding a CI_Contact entry.
<ows:ExceptionText>
company:contactInfo java.io.IOException null Schema 'person' does not exist.
Software Engineer
Attached is stack trace…
Appears to be having issue with sql…
I think I know where the issue might be… it is possible it is trying to join between two databases.
(It was)
I have two different databases and two different jdbc connections, each project uses their own… except…
An app-schema feature can only describe a single jdbc datasource, so even though each db has their own version of the ‘ci_contact’ and friends table, when app-schema does a query its locked into the one jdbc datasource.
I guess if I want to implement separate db’s which share another common featureType from an external namespace i’ll need to have separate geoservers or have it within a single database schema.
Thanks
stack-trace.txt (16.3 KB)
On 14 October 2013 17:34, Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com> wrote:
ows:ExceptionText
Software Engineer
Aha! Because app-schema can use separate connections for different feature types, it should work with chaining across different databases, but only if joining is turned off. It looks like you have found a use-case that does not automatically turn off joining; this is a bug. You can manually turn off joining in your app-schema.properties file:
http://docs.geoserver.org/latest/en/user/data/app-schema/joining.html#conditions
Kind regards,
Ben.
On 15/10/13 07:11, snuffy wrote:
Attached is stack trace..
Appears to be having issue with sql..
I think I know where the issue might be.. it is possible it is trying to
(It was)
project uses their own.. except..
even though each db has their own version of the 'ci_contact' and
datasource.
I guess if I want to implement separate db's which share another common
featureType from an external namespace i'll need to have separate
Thanks
        <ows:ExceptionText>
        targetAttribute
        does not exist.
    Software Engineer
Software Engineer
Perhaps we could improve the joining setting by applying it per feature type, instead of per GeoServer instance.
I raised this task, but I can't commit on working on it anytime soon.
https://jira.codehaus.org/browse/GEOT-4596
-----Original Message-----
Sent: Tuesday, 15 October 2013 9:47 AM
To: snuffy
Cc: geoserver-users@lists.sourceforge.net; Angreani, Rini (CESRE, Kensington)
Subject: Re: [Geoserver-users] App-schema and CharacterString Type
Kind regards,
Ben.
(It was)
each project uses their own.. except..
jdbc datasource.
common featureType from an external namespace i'll need to have
Thanks
        <ows:ExceptionText>
        targetAttribute
        does not exist.
    Ben Caradoc-Davies <Ben.Caradoc-Davies@...367...>
    Software Engineer
Ben Caradoc-Davies <Ben.Caradoc-Davies@...367...> Software Engineer CSIRO Earth Science and Resource Engineering Australian Resources Research Centre
Sounds good,
I’d almost like an ‘override’ parameter or similar attached to the datastore definition that I could then say:
true
Which when applied would use the JDBC connection of the feature requesting the linkage to this feature.
aka:
Person pulls in CI_Contact, therefore override the jndi connection specified by CI_Contact (if forceLinkJNDI = true) to be Person’s JNDI information.
I’m not sure how possible that is because I have not reviewed the code in that respect.
PS: i noticed some sorting related changes on the git tree for app-schema recently, does any of those changes remove the odd requirement of needing the idExpression table column in the feature being linked to (because of sorting)?
I raised this task, but I can’t commit on working on it anytime soon.
To: snuffy
Kind regards,
Ben.
(It was)
jdbc datasource.
Thanks
<Ben.Caradoc-Davies@anonymised.com mailto:[Ben.Caradoc-Davies@anonymised.com](mailto:Ben.Caradoc-Davies@anonymised.com)> wrote:
ows:ExceptionText
targetAttribute
does not exist.
Software Engineer
Ben Caradoc-Davies Ben.Caradoc-Davies@anonymised.com Software Engineer CSIRO Earth Science and Resource Engineering Australian Resources Research Centre
That’s not possible with the current joining implementation, as it uses INNER JOIN between the linked tables – not possible across different databases.
It has to use the old implementation (without joining), which is painfully slow for large datasets.
It’s probably OK for demonstration purposes where there are only a few records, but for production, I would recommend using joining (with one database).
Re: sorting changes, it was to cater for database views where idExpression is not specified and the primary keys aren’t available.
If your table has primary keys, then it would sort by the primary key in absence of the idExpression. I also replied to your other thread regarding this.
Rini
Sent: Tuesday, 15 October 2013 12:47 PM
To: Angreani, Rini (CESRE, Kensington)
Cc: Caradoc-Davies, Ben (CESRE, Kensington); geoserver-users@anonymised.comourceforge.net
Sounds good,
true
aka:
To: snuffy
Kind regards,
Ben.
(It was)
jdbc datasource.
Thanks
ows:ExceptionText
targetAttribute
does not exist.
Software Engineer
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com> Software Engineer CSIRO Earth Science and Resource Engineering Australian Resources Research Centre
Ideally, the code should be able to do that on a per join basis: same
store, jdbc type, use joining, otherwise,
use the old strategy (inner loop?)
Our support, Your Success! Visit http://opensdi.geo-solutions.it for more
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
That’s a good idea, but that would make it more complicated to implement.
Will consider it when I have the time to do this.
Rini
From: andrea.aime@anonymised.com [mailto:andrea.aime@anonymised.com] On Behalf Of Andrea Aime
Sent: Tuesday, 15 October 2013 2:01 PM
Cc: Caradoc-Davies, Ben (CESRE, Kensington); snuffy22@anonymised.com; GeoServer Mailing List List
Ideally, the code should be able to do that on a per join basis: same store, jdbc type, use joining, otherwise,
Ing. Andrea Aime
@geowolf
Technical Lead
