[Geoserver-users] App-Schema Custom GetFeatureInfo HTML
Hello,
Apologies for asking the same question twice, I was unsure if my question below had reached the mailing list – if anyone could provide me with any information regarding the query below, it would be really appreciated :slight_smile:
Many thanks,
Ryan
From: Ryan Moody [mailto:ryan.moody@anonymised.com]
Sent: 08 November 2013 16:34
Cc: Francoise Kingman; Neil Kirk
Subject: [Geoserver-users] App-Schema Custom GetFeatureInfo HTML
Hello,
Having successfully got my App-Schema based WMS to return a PNG image, I now wish to override the GetFeatureInfo request to output custom HTML. I’ve defined the following content.ftl template:
=== Begin content.ftl
<#list features as feature>
  • ${feature.fid}
    • <#list feature.attributes as attribute>
      <#if attribute.name != “the_geom”>
    • ${attribute.name} = ${attribute.value}
    • </#if>
      </#list>
</#list>
=== End content.ftl
This template gives me the bullet point list I expect to see for the tutorial (non App-Schema) data layers when I invoke a GetFeatureInfo request by clicking on the OpenLayers map, however, when I use the same content.ftl for my App-Schema data layer, the default HTML (a table of attributes instead of my custom bulleted list) is displayed.
Does App-Schema support the use of a custom content.ftl template? If so, what modifications do I need to make to make to the template above in order to display the bulleted list?
Best Regards,
Ryan
On Wed, Nov 20, 2013 at 5:23 PM, Ryan Moody <ryan.moody@anonymised.com> wrote:
Hello,
As far as I can see, if the feature is a complex one, a different template
is used, complex_content.ftl.
The default one seems to contain this:
Macro's used for content
<#macro property node>
    <#if !node.isGeometry>
       <#if node.isComplex>
       <td> <@feature node=node.rawValue type=node.type /> </td>
      <#else>
      <td>${node.value?string}</td>
      </#if>
    </#if>
</#macro>
<#macro header typenode>
<caption class="featureInfo">${typenode.name}</caption>
  <tr>
  <th>fid</th>
<#list typenode.attributes as attribute>
  <#if !attribute.isGeometry>
    <#if attribute.prefix == "">
    <th >${attribute.name}</th>
    <#else>
    <th >${attribute.prefix}:${attribute.name}</th>
    </#if>
  </#if>
</#list>
  </tr>
</#macro>
<#macro feature node type>
<table class="featureInfo">
  <@header typenode=type />
  <tr>
  <td>${node.fid}</td>
  <#list node.attributes as attribute>
      <@property node=attribute />
  </#list>
  </tr>
</table>
</#macro>
Body section of the GetFeatureInfo template, it's provided with one feature
collection, and
will be called multiple times if there are various feature collections
<#assign odd = false>
  <#if odd>
    <tr class="odd">
  <#else>
    <tr>
  </#if>
  <#assign odd = !odd>
  <td>${feature.fid}</td>
  </#list>
  </tr>
</#list>
</table>
<br/>
Hope this helps
Our support, Your Success! Visit http://opensdi.geo-solutions.it for more
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Andrea, you’re a star! I’ve renamed my template from content.ftl to complex_content.ftl and this has worked perfectly – thank you very much :slight_smile:
Best Regards,
Ryan
From: andrea.aime@anonymised.com84… [mailto:andrea.aime@anonymised.com] On Behalf Of Andrea Aime
Sent: 20 November 2013 16:38
To: Ryan Moody
Cc: GeoServer Mailing List List; Francoise Kingman; Neil Kirk
Subject: Re: [Geoserver-users] App-Schema Custom GetFeatureInfo HTML
Hello,
As far as I can see, if the feature is a complex one, a different template is used, complex_content.ftl.
Macro’s used for content
<#else>
</#if>
</#if>
</#macro>
${[typenode.name](http://typenode.name)} fid
<#if attribute.prefix == “”>
${[attribute.name](http://attribute.name)}
<#else>
${attribute.prefix}:${[attribute.name](http://attribute.name)}
</#if>
</#if>
</#list>
</#macro>
</#list>
${node.fid}
</#macro>
Body section of the GetFeatureInfo template, it’s provided with one feature collection, and
<#if odd>
<#else>
</#if>
</#list>
</#list>
${feature.fid}
Hope this helps
Ing. Andrea Aime
@geowolf
Technical Lead
On Mon, Nov 25, 2013 at 10:44 AM, Ryan Moody <ryan.moody@anonymised.com> wrote:
Happy to be of help.
If you have time, could you open a ticket at
http://jira.codehaus.org/browse/GEOS to report the missing bit in the
documentation?
(or if you have even more time, provide a patch for the docs? :-p )
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Sorry I just only saw this email. I implemented this.
This is in fact already documented:
http://docs.geoserver.org/latest/en/user/data/app-schema/wms-support.html#getfeatureinfo
Regards
Niels
On 25/11/13 10:58, Andrea Aime wrote:
On Mon, Nov 25, 2013 at 10:44 AM, Ryan Moody <ryan.moody@anonymised.com <mailto:ryan.moody@anonymised.com>> wrote:
    Andrea, you're a star! I've renamed my template from content.ftl
    to complex_content.ftl and this has worked perfectly -- thank you
If you have time, could you open a ticket at http://jira.codehaus.org/browse/GEOS to report the missing bit in the documentation?
Ing. Andrea Aime
@geowolf
Technical Lead
Shape the Mobile Experience: Free Subscription
Software experts and developers: Be at the forefront of tech innovation.
Intel(R) Software Adrenaline delivers strategic insight and game-changing
conversations that shape the rapidly evolving mobile landscape. Sign up now.
http://pubads.g.doubleclick.net/gampad/clk?id=63431311&iu=/4140/ostg.clktrk
Geoserver-users mailing list
