[Moved to GeoServer users list]
Stefano,
I could not see anything obvious in your mapping file. Do you have a secondary namespace configured for gml?
http://docs.geoserver.org/latest/en/user/data/app-schema/supported-gml-versions.html#secondary-namespace-for-gml-3-2-1-required
I did not see anything obviously wrong with the schemas, either. GeoServer app-schema guesses GML version based on whether a GML 3.1 or 3.2 feature base type is present. I did not see anything that could import GML 3.1.1.
In the past I have seen GML 3.2.1 application schemas that mistakenly import GML 3.1.1 and cause GeoServer app-schema to load the wrong Java bindings. If GeoServer finds both, it will pick GML 3.1.1; see SUPPORTED_GML_KNOWN_TYPE_TO_CONFIGURATION_MAP and findGmlConfiguration in GmlFeatureTypeRegistryConfiguration. This is a schema problem as a GML application schema should use only one version of GML.
Try removing your app-schema-cache and restarting (with only this one feature type mapped) to see if any GML 3.1.1 schemas are downloaded into the cache.
Kind regards,
Ben.
On 14/07/15 00:43, stefano.costa wrote:
I'm facing an issue with a simple app-schema mapping targeting the Geology Core INSPIRE schema, which can be found here:
file:///home/stefano/Lavoro/GeoSolutions/projects/hale/geoserver-2.6.2/data_dir/app-schema-cache/eu/europa/ec/inspire/schemas/ge-core/3.0/GeologyCore.xsdI'm attaching a simplified version of the mapping file.
Stack trace of the error:
java.lang.RuntimeException: Failed to get properties. Binding for {http://www.opengis.net/gml\}AbstractFeatureType
at org.geotools.xml.impl.GetPropertiesExecutor.visit(GetPropertiesExecutor.java:72)
at org.geotools.xml.impl.BindingWalker$BindingExecutionChain.execute(BindingWalker.java:220)
at org.geotools.xml.impl.BindingWalker.walk(BindingWalker.java:186)
at org.geotools.xml.impl.BindingVisitorDispatch.walk(BindingVisitorDispatch.java:47)
at org.geotools.xml.impl.BindingVisitorDispatch.walk(BindingVisitorDispatch.java:32)
at org.geotools.xml.impl.BindingPropertyExtractor.properties(BindingPropertyExtractor.java:96)
at org.geotools.xml.Encoder.encode(Encoder.java:960)
at org.geotools.xml.Encoder.encode(Encoder.java:609)
at org.geoserver.wfs.xml.GML32OutputFormat.encode(GML32OutputFormat.java:124)
at org.geoserver.wfs.xml.GML3OutputFormat.complexFeatureStreamIntercept(GML3OutputFormat.java:325)
at org.geoserver.wfs.xml.GML3OutputFormat.write(GML3OutputFormat.java:277)
at org.geoserver.wfs.WFSGetFeatureOutputFormat.write(WFSGetFeatureOutputFormat.java:196)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:992)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:279)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:83)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:135)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:83)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:88)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:76)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:324)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:828)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:514)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
at org.mortbay.jetty.bio.SocketConnector$Connection.run(SocketConnector.java:228)
at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
Caused by: java.lang.RuntimeException: Could not find type for {http://inspire.ec.europa.eu/schemas/ge-core/3.0\}NaturalGeomorphologicFeatureType in schema
at org.geotools.gml2.bindings.GMLEncodingUtils.AbstractFeatureType_getProperties(GMLEncodingUtils.java:140)
at org.geotools.gml3.bindings.GML3EncodingUtils.AbstractFeatureTypeGetProperties(GML3EncodingUtils.java:312)
at org.geotools.gml3.bindings.AbstractFeatureTypeBinding.getProperties(AbstractFeatureTypeBinding.java:145)
at org.geotools.xml.impl.GetPropertiesExecutor.visit(GetPropertiesExecutor.java:65)
... 88 moreFrom the error message of the exception's root cause, marked in red, it looks like NaturalGeomorphologicFeatureType was not properly parsed and added to the schema index, not sure why. Also the message "Failed to get properties. Binding for {http://www.opengis.net/gml\}AbstractFeatureType" sounds wrong to me: shouldn't have been "{http://www.opengis.net/gml/3\.2\}AbstractFeatureType", since the geology schema links to GML 3.2?
I tried to change output format to "gml3" and the exception disappears, although the output is not perfect (e.g. "shape" geometry element is not properly encoded):<wfs:FeatureCollection numberOfFeatures="50"
timeStamp="2015-07-13T12:38:29.217Z"
xsi:schemaLocation="http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd http://inspire.ec.europa.eu/schemas/ge-core/3.0/GeologyCore.xsd">
<gml:featureMember>
<ge:MappedFeature gml:id="pilota.1">
<ge:shape></ge:shape>
<ge:mappingFrame
xlink:href="http://inspire.ec.europa.eu/codelist/MappingFrameValue/surfaceGeology"
xlink:type="simple" />
<ge:specification>
<ge:NaturalGeomorphologicFeature>
<ge:activity
xlink:href="http://inspire.ec.europa.eu/codelist/GeomorphologicActivityValue/dormant"
</ge:NaturalGeomorphologicFeature>
</ge:specification>
</ge:MappedFeature>
</gml:featureMember>I tested with GeoServer 2.7.1 and master, obtaining similar results.
Does anybody have an idea of what might be going wrong?
Best regards,
Stefano Costa==
http://goo.gl/it488V for more information.Dott. Stefano Costa
Senior Software EngineerGeoSolutions S.A.S.
Via Poggio alle Viti 1187
fax: +39 0584 1660272http://www.geo-solutions.it
http://twitter.com/geosolutions_it-------------------------------------------------------
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.------------------------------------------------------------------------------
Don't Limit Your Business. Reach for the Cloud.
GigeNET's Cloud Solutions provide you with the tools and support that
you need to offload your IT needs and focus on growing your business.
Configured For All Businesses. Start Your Cloud Today.
https://www.gigenetcloud.com/_______________________________________________
GeoTools-GT2-Users mailing list
GeoTools-GT2-Users@lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geotools-gt2-users
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/>
New Zealand
