[Geoserver-users] app-schema mapping.properties file location
The Geoserver app-schema documentation (http://docs.geoserver.org/latest/en/user/data/app-schema/cql-functions.html) has the example:
Vocab(ABBREVIATION, ‘/test-data/mapping.properties’)
Where does this mapping.properties file go in the geoserver/data directory structure?
Wherever I put it I get the error:
“Error applying mapping with targetAttribute om:observedProperty Argument “value” should not be null”
Bruce Simons
Information Modeller
CSIRO Land and Water/ Environmental Information Infrastructures
E: bruce.simons@anonymised.com T: +61 3 9252 6514 M: +61 475 954 391
PO Box 56, Highett, Victoria, 3190
Bruce,
in a nutshell: ugly and not as documented, but it should work if you use an absolute path.
The documentation claims that the properties file can be an absolute path or relative to the mapping file, but I had a look in the implementation and I see no evidence of handling of paths relative to the mapping file:
Even the test coverage is relative to the home directory of the GeoTools module. Whatever you pass as the properties file "URI" (and it is not a URI) is used raw as a path; if relative it is relative to the current working directory of the process (not useful), and if absolute it is the absolute path on the filesystem (ugly but workable).
For example, if GeoServer is running in Tomcat 7 on Debian and you put the mapping file in the root of the data directory, you might have something like this:
<OCQL>Vocab(ABBREVIATION, '/var/lib/tomcat7/webapps/geoserver/data/mapping.properties')</OCQL>
You may also need to change the permissions to make sure Tomcat can read the file:
chmod 644 /var/lib/tomcat7/webapps/geoserver/data/mapping.properties
Kind regards,
Ben.
<OCQL>Vocab(ABBREVIATION, '/test-data/mapping.properties')</OCQL>
"Error applying mapping with targetAttribute om:observedProperty Argument "value" should not be null"
Bruce Simons
E: bruce.simons@anonymised.com<mailto:bruce.simons@anonymised.com> T: +61 3 9252 6514 M: +61 475 954 391
Geoserver-users mailing list
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
Thanks Ben,
Putting the absolute path worked without the chmod:
<AttributeMapping>
  <targetAttribute>om:observedProperty</targetAttribute>
    <ClientProperty>
    <name>xlink:href</name>
    <value>Vocab(METHOD, 'C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\geoserver\data\workspaces\om\OM_Observation\mapping.properties')</value>
  </ClientProperty>
</AttributeMapping>
Can you report this as a bug change request for me?
Bruce Simons
E: bruce.simons@...367... T: +61 3 9252 6514 M: +61 475 954 391
-----Original Message-----
Sent: Wednesday, 18 November 2015 5:41 AM
To: Simons, Bruce (L&W, Clayton) <Bruce.Simons@...367...>
Cc: geoserver-users@lists.sourceforge.net; Jody Garnett <jody.garnett@...84...>
Subject: Re: [Geoserver-users] app-schema mapping.properties file location
Bruce,
Kind regards,
Ben.
Bruce Simons
E: bruce.simons@...367...<mailto:bruce.simons@…367…> T: +61 3 9252
6514 M: +61 475 954 391 PO Box 56, Highett, Victoria, 3190
Ben Caradoc-Davies <ben@...6881...>
Director
Transient Software Limited <http://transient.nz/&gt; New Zealand
Bruce,
thanks for the confirmation. I have reported this bug in Jira:
[GEOT-5308] app-schema Vocab function does not honour relative vocabulary properties file path
https://osgeo-org.atlassian.net/browse/GEOT-5308
Kind regards,
Ben.
On 18/11/15 10:59, Bruce.Simons@anonymised.com wrote:
Thanks Ben,
<AttributeMapping>
     <ClientProperty>
  </ClientProperty>
</AttributeMapping>
Bruce Simons
From: Ben Caradoc-Davies [mailto:ben@anonymised.com]
To: Simons, Bruce (L&W, Clayton) <Bruce.Simons@anonymised.com>
Cc: geoserver-users@lists.sourceforge.net; Jody Garnett <jody.garnett@anonymised.com>
Bruce,
Kind regards,
Ben.
Bruce Simons
Director
Director
New Zealand
Bruce,
in this week's code sprint I implemented an improvement that makes the CQL Vocab function easier to use. I also updated the documentation to note the requirement for an absolute path as the second argument to Vocab.
[GEOT-5308] Support predefined app-schema interpolation properties for mapping file and parent directory
You can now use:
<AttributeMapping>
<targetAttribute>gml:name</targetAttribute>
<sourceExpression>
<OCQL>Vocab(ABBREVIATION, strconcat('${config.parent}', '/mapping.properties'))</OCQL>
</sourceExpression>
</AttributeMapping>
In each mapping file, ${config.parent} is set automatically to the parent directory of that mapping file; this requires no configuration. For more details, see:
http://docs.geoserver.org/stable/en/user/data/app-schema/cql-functions.html#vocab
http://docs.geoserver.org/stable/en/user/data/app-schema/property-interpolation.html#predefined-properties
This change has been applied to master and 2.9.x and will be included in 2.9.1.
Kind regards,
Ben.
On 18/11/15 11:15, Ben Caradoc-Davies wrote:
Bruce,
Kind regards,
Ben.
Thanks Ben,
<AttributeMapping>
     <ClientProperty>
  </ClientProperty>
</AttributeMapping>
Bruce Simons
Bruce,
Kind regards,
Ben.
Bruce Simons
Director
Director
New Zealand
