Tomas,
I recommend getting WFS working first as it is easiest to debug.
(1) Do not use workspace-specific service URLs as they cannot work with app-schema because GeoServer assumes a one-to-one workspace to namespace relationship. Removing the workspace does not fix your problem but it will be required.
Change: http://bolegweb.geof.unizg.hr/geoserver/proplant/wms
To: http://bolegweb.geof.unizg.hr/geoserver/wms
(but get WFS working first)
(2) Your geometries have a null namespace prefix that should be gml:
http://bolegweb.geof.unizg.hr/geoserver/wfs?service=WFS&version=2.0.0&request=GetFeature&typenames=proplant:observations&count=10
Did you define a GML 3.2.1 secondary namespace as required by app-schema?
http://docs.geoserver.org/latest/en/user/data/app-schema/supported-gml-versions.html#secondary-namespace-for-gml-3-2-1-required
(3) Your schema imports itself. It should instead import the GML 3.2.1 schema. Until it does, it is not a GML application schema.
http://bolegweb.geof.unizg.hr/proplant/xsd/proplant_observations.xsd
I am surprised it works at all. I expected to see:
<xsd:import namespace="http://www.opengis.net/gml/3.2" schemaLocation="http://schemas.opengis.net/gml/3.2.1/gml.xsd"/>
(4) WFS DescribeFeatureType fails with "java.io.IOException: Error occurred building feature type Error occurred building feature type ERROR: relation "objekt_obveznik_naselje_area_total_spatial" does not exist Position: 31"
http://bolegweb.geof.unizg.hr/geoserver/wfs?service=WFS&version=2.0.0&request=DescribeFeatureType&typenames=proplant:observations
(5) Your feature type looks very close to an OGC SF-0 simple feature. An alternative method is to deliver your data with GeoServer schema mapping. This option is completely separate to app-schema and may work in this simple case. I have not used it with WMS:
http://docs.geoserver.org/stable/en/user/services/wfs/schemamapping.html
Kind regards,
Ben.
On 05/03/16 04:01, Tomas Kliment wrote:
Dear users,
Could you help me to understand what is wrong with my set up of app schema
plugin and its application on one simple featureType.
GetMap request results in the following error:
<?xml version="1.0"
encoding="UTF-8"?><ServiceExceptionReport version="1.3.0" xmlns="
http://www.opengis.net/ogc" xmlns:xsi="
http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="
http://bolegweb.geof.unizg.hr/geoserver/schemas/wms/1.3.0/exceptions_1_3_0.xsd
"> <ServiceException>
java.lang.ClassCastException:
org.geoserver.security.decorators.ReadOnlyDataAccess cannot be cast to
org.geotools.data.DataStore
</ServiceException></ServiceExceptionReport>
http://bolegweb.geof.unizg.hr/geoserver/proplant/wms?service=WMS&version=1.3.0&request=GetMap&layers=proplant:observations&styles=&bbox=20.522657679466,48.6046642023666,20.6049912088275,48.6113374332541&width=4071&height=330&srs=EPSG:4326&format=application/openlayers
Has anyone experienced similar problem and could help me?
On THIS
<https://drive.google.com/file/d/0B_LYIq94gSDiYW1pLWpYY1dnZVE/view?usp=sharing>
link is the whole workspace defining the new schema
(proplant_observations.xsd), mapping file (proplant_observations.xml) etc.
Thank you in advance,
Tomas
Site24x7 APM Insight: Get Deep Visibility into Application Performance
APM + Mobile APM + RUM: Monitor 3 App instances at just $35/Month
Monitor end-to-end web transactions and take corrective actions now
Troubleshoot faster and improve end-user experience. Signup Now!
http://pubads.g.doubleclick.net/gampad/clk?id=272487151&iu=/4140
Geoserver-users mailing list
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/>
New Zealand
