Sylvain,
your "am" and "base" namespace prefix uris are both wrong.
You have:
<Namespace>
<prefix>am</prefix>
<uri>http://inspire.ec.europa.eu/schemas/am</uri>
</Namespace>
However, the imported schema that defines in am:ManagementRestrictionOrRegulationZoneType (the parent type of the target) its targetNamespace:
http://inspire.ec.europa.eu/draft-schemas/am/3.0rc3/AreaManagementRestrictionRegulationZone.xsd
has
targetNamespace="http://inspire.ec.europa.eu/schemas/am/3.0rc3"
You also have:
<Namespace>
<prefix>base</prefix>
<uri>urn:x-inspire:specification:gmlas:BaseTypes:3.2</uri>
</Namespace>
However, the imported schema that defines base:IdentifierType in its targetNamespace:
http://inspire.ec.europa.eu/draft-schemas/base/3.3rc3/BaseTypes.xsd
has
targetNamespace="http://inspire.ec.europa.eu/schemas/base/3.3rc3/"
GeoServer app-schema thus correctly reports that the location path does not exist.
These look like poor choices for namespace URIs. Please check with INSPIRE as they might be an error, possibly caused by a shift to HTTP URI namespaces colliding with automatic search-and-replace for schema management. Note also the inconsistent trailing slash for "base". Namespace URIs should not vary with patch/bugfix (and an rc is like these). See OGC 06-135r11 "Policy Directives for Writing and PublishingOGC Standards: TC Decisions":
http://portal.opengeospatial.org/files/?artifact_id=40077
On p11: "13.3.2 Version designator [...] The bug fix version
designator SHALL NOT appear in the XML namespace."
Always use prefixes in a location path, not URIs; the presence of any colons will break xpath parsing.
Kind regards,
Ben.
On 30/07/13 21:04, Sylvain GRELLET wrote:
Dear list,
We have an issue having the app-schema work on inherited properties.
The context :
- Geoserver 2-2 and WFS app-schema that works fine in other simple mappings.
- xsd generated using Enterprise Architect + ShapeChange
- the featureType we want to expose inherits from a class that is_in
another schema_ (xsd). Actually we specialize Inspire
ManagementRestrictionOrRegulationZone class (see attached model pdf + xsd)
Below are the various tests I tried
1° / using the expected 'am' prefix -> am:inspireId...
=> "java.lang.RuntimeException: /Failed to get property: ... Error
applying mapping with targetAttribute
am:inspireId/base:Identifier/base:localId am:inspireId is not a valid
location path for type
http://xml.uwwtd.oieau.fr/schemas/0.1:UWWTD_AgglomerationType ...
properties:...,http://inspire.ec.europa.eu/schemas/am/3.0rc3#inspireId,...//
2°/ the error above proposed a list of properties to use
using the namespace as advised in the error
(http://inspire.ec.europa.eu/schemas/am/3.0rc3#inspireId) generates
"/Error occurred getting features //
//java.lang.StringIndexOutOfBoundsException: String index out of range:
0 String index out of range: 0/"
3°/ are the slashes of the url used in an xPath processing of some sort
? => tried to escape the slashes in the namespace
=> /Error occurred getting features java.lang.IllegalArgumentException:
location step http:\ has prefix http for which no namespace was set.
(Check the Namespaces section in the config file)/
4°/ mapping file states "/Imports and includes at the schemas will be
followed as long as they're relative paths/" => changed the original xsd
to have relative paths => ko
5°/ declared multiple <schemaUri> in <targetTypes><FeatureType><schemaUri>
=> seems only the first one is used
6°/ no prefix in the <targetAttribute> : ko
What are we missing ?
I also attached a light version of the configuration file
Should we upgrade to V 2.3.4 or 2.4-beta ?
Many thanks
Sylvain
Get your SQL database under version control now!
Version control is standard for application code, but databases havent
caught up. So what steps can you take to put your SQL databases under
version control? Why should you start doing it? Read more to find out.
http://pubads.g.doubleclick.net/gampad/clk?id=49501711&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
