In the process of trying to link features from multiple INSPIRE Themes via Feature Chaining, I’ve run into difficulties using multiple (well 2) databases (was trying to do one database per feature type/namespace). To clarify that it’s not a problem with my configuration I put together a simple example consisting of a main feature with two nested features, one of which should stem from a different DB than the main parts. (schema available at http://www.schleidt.org/schemas/test.xsd)
Within the main DB (test2, DataStore idDataStoreTS), there are 2 tables:
* testmain: the main part
* nest: the part that should actually be in the other database
Within the 2^nd DB (nest2, DataStore idDataStoreNS), there is only the nest table (identical to the one in test, just different content to see where the data is coming from)
The DataStore configuration for both databases is identical except for the database name (test2 vs nest2)
As long as I’m only using the main database (test2), everything works out beautifully. The moment I try to use the 2^nd database connection (nest2), while there are no errors on startup, there are also no features, just the following error (for ts:nestExt it should be going for the table nest in the db nest2, but it’s complaining about the table testmain from the db test2):
java.lang.RuntimeException: Error applying mapping with targetAttribute ts:nestExt
java.io.IOExceptionSchema 'testmain' does not exist.
An interesting aside – when I set up this test, I first forgot to set up my db as postgis (I’m an old geek, and spatial is still new to me). This worked fine as long as I was only using one DB (there are no geometries in my simple example), when I added the 2^nd one I got an interesting PostGis error (might help in debugging):
Function postgis_lib_version() doesn’t exist
Configuration and logfiles are available at: http://www.schleidt.org/kathi/DBProblem.zip
Main problem in the subdirectory PostGisDB, the 2 variants with just PostGres are PostGres1 & 2 (for 1 or 2 dbs)
Can somebody tell me if I'm going crazy or if there's a problem here?
Kathi
_________________________________________________________________________
Katharina Schleidt
Tel: +43 (1) 89 234 26
Mobile: +43 (650) 89 234 26
Skype: Kathi Schleidt
Kathi@anonymised.com
The world is a dangerous place to live; not because of the people who are evil, but because of the people who don't do anything about it - Albert Einstein
Growth for the sake of growth is the ideology of the cancer cell – Edward Abbey
If at first, the idea is not absurd, then there is no hope for it - Albert Einstein
