[Geoserver-users] app-schema tries to access non-existent objectid column
I am using GeoServer v2.4RC1 with app-schema plugin to map 3 related PostGIS tables to GeoSciML v3.2 features.
I'm getting an error about trying to access a column which doesn't exist in the underlying table although no part of my mapping files refer to this column. Below I include the error message, the SQL query which GeoServer is trying to execute (taken from PostgreSQL logs) and the bits of the mapping file that specify the feature chaining between the two features that seem to be relevant to the error. I've set app-schema.joining = true explicitly although I believe this should be the default anyway for this version of GeoServer.
Any ideas why GeoServer is trying to access the objectid column of my table?
Marcus Sen
The relevant part of the error message is:
Caused by: java.lang.RuntimeException: Error applying mapping with targetAttribute gsml:specification
        at org.geotools.data.complex.DataAccessMappingFeatureIterator.computeNext(DataAccessMappingFeatureIterator.java:1018)
        at org.geotools.data.complex.AbstractMappingFeatureIterator.next(AbstractMappingFeatureIterator.java:338)
        at org.geotools.data.complex.MappingFeatureCollection.getBounds(MappingFeatureCollection.java:197)
        ... 90 more
Caused by: java.lang.RuntimeException: java.io.IOException
        at org.geotools.data.store.ContentFeatureCollection.features(ContentFeatureCollection.java:168)
        at org.geotools.data.store.ContentFeatureCollection.features(ContentFeatureCollection.java:59)
        at org.geotools.data.complex.DataAccessMappingFeatureIterator.initialiseSourceFeatures(DataAccessMappingFeatureIterator.java:377)
        at org.geotools.data.complex.AbstractMappingFeatureIterator.<init>(AbstractMappingFeatureIterator.java:206)
        at org.geotools.data.complex.AbstractMappingFeatureIterator.<init>(AbstractMappingFeatureIterator.java:152)
        at org.geotools.data.complex.DataAccessMappingFeatureIterator.<init>(DataAccessMappingFeatureIterator.java:160)
        at org.geotools.data.complex.MappingFeatureIteratorFactory.getInstance(MappingFeatureIteratorFactory.java:146)
        at org.geotools.data.complex.MappingFeatureCollection.features(MappingFeatureCollection.java:174)
        at org.geotools.data.joining.JoiningNestedAttributeMapping.initSourceFeatures(JoiningNestedAttributeMapping.java:204)
        at org.geotools.data.joining.JoiningNestedAttributeMapping.getFeatures(JoiningNestedAttributeMapping.java:383)
        at org.geotools.data.complex.DataAccessMappingFeatureIterator.setAttributeValue(DataAccessMappingFeatureIterator.java:568)
        at org.geotools.data.complex.DataAccessMappingFeatureIterator.computeNext(DataAccessMappingFeatureIterator.java:1005)
        ... 92 more
Caused by: java.io.IOException
        at org.geotools.jdbc.JoiningJDBCFeatureSource.getJoiningReaderInternal(JoiningJDBCFeatureSource.java:659)
        at org.geotools.jdbc.JoiningJDBCFeatureSource.getReaderInternal(JoiningJDBCFeatureSource.java:667)
        at org.geotools.data.store.ContentFeatureSource.getReader(ContentFeatureSource.java:563)
        at org.geotools.data.store.ContentFeatureCollection.features(ContentFeatureCollection.java:165)
        ... 103 more
Caused by: org.postgresql.util.PSQLException: ERROR: column uk_625k_bedrock_geol_unit.objectid does not exist
  Position: 2944
        at org.postgresql.core.v3.QueryExecutorImpl.receiveErrorResponse(QueryExecutorImpl.java:2062)
I am using Feature chaining between the tables so for example in my gsml_MappedFeature.xml mapping file which maps the UK_625K_BEDROCK_WGS84 table to gsml:MappedFeature features I have the section:
<AttributeMapping>
        <targetAttribute>gsml:specification</targetAttribute>
        <sourceExpression>
                <OCQL>lex_rcs</OCQL>
          <linkElement>gsmlgu:GeologicUnit</linkElement>
                <linkField>FEATURE_LINK</linkField>
        </sourceExpression>
</AttributeMapping>
and in my gsmlgu_GeologicUnit.xml mapping file which maps the uk_625k_bedrock_geol_unit table to gsmlgu:GeologicUnit features I have the section:
<AttributeMapping>
        <targetAttribute>FEATURE_LINK</targetAttribute>
        <sourceExpression><OCQL>lex_rcs</OCQL></sourceExpression>
</AttributeMapping>
The query which GeoServer tries to execute is:
SELECT "public"."uk_625k_bedrock_geol_unit"."lex_rcs",
"public"."uk_625k_bedrock_geol_unit"."lex",
"public"."uk_625k_bedrock_geol_unit"."rcs",
"public"."uk_625k_bedrock_geol_unit"."name_urn",
"public"."uk_625k_bedrock_geol_unit"."name",
"public"."uk_625k_bedrock_geol_unit"."lex_d",
"public"."uk_625k_bedrock_geol_unit"."rank",
"public"."uk_625k_bedrock_geol_unit"."ics_urn",
"public"."uk_625k_bedrock_geol_unit"."rcs_urn",
"public"."uk_625k_bedrock_geol_unit"."oge_geologicunittype",
"public"."uk_625k_bedrock_geol_unit"."oge_age_max",
"public"."uk_625k_bedrock_geol_unit"."oge_age_min",
"public"."uk_625k_bedrock_geol_unit"."oge_eventenvironment",
"public"."uk_625k_bedrock_geol_unit"."oge_eventprocess",
"public"."uk_625k_bedrock_geol_unit"."oge_lithology_1",
"public"."uk_625k_bedrock_geol_unit"."oge_proportionterms_1",
"public"."uk_625k_bedrock_geol_unit"."oge_geologicunitpartrole_1",
"public"."uk_625k_bedrock_geol_unit"."oge_lithology_2",
"public"."uk_625k_bedrock_geol_unit"."oge_proportionterms_2",
"public"."uk_625k_bedrock_geol_unit"."oge_geologicunitpartrole_2",
"public"."uk_625k_bedrock_geol_unit"."oge_lithology_3",
"public"."uk_625k_bedrock_geol_unit"."oge_proportionterms_3",
"public"."uk_625k_bedrock_geol_unit"."oge_geologicunitpartrole_3",
"public"."uk_625k_bedrock_geol_unit"."oge_lithology_4",
"public"."uk_625k_bedrock_geol_unit"."oge_proportionterms_4",
"public"."uk_625k_bedrock_geol_unit"."oge_geologicunitpartrole_4",
"public"."uk_625k_bedrock_geol_unit"."oge_lithology_5",
"public"."uk_625k_bedrock_geol_unit"."oge_proportionterms_5",
"public"."uk_625k_bedrock_geol_unit"."oge_geologicunitpartrole_5",
"public"."uk_625k_bedrock_geol_unit"."oge_metamorphicgrade",
"public"."uk_625k_bedrock_geol_unit"."oge_geologicunittype_uri",
"public"."uk_625k_bedrock_geol_unit"."oge_eventenvironment_uri",
"public"."uk_625k_bedrock_geol_unit"."oge_eventprocess_uri",
"public"."uk_625k_bedrock_geol_unit"."oge_metamorphic_grade_uri",
"public"."uk_625k_bedrock_geol_unit"."oge_geologicunittype_label",
"public"."uk_625k_bedrock_geol_unit"."oge_age_max_label",
"public"."uk_625k_bedrock_geol_unit"."oge_age_min_label",
"public"."uk_625k_bedrock_geol_unit"."oge_eventenvironment_label",
"public"."uk_625k_bedrock_geol_unit"."oge_eventprocess_label",
"public"."uk_625k_bedrock_geol_unit"."oge_metamorphic_grade_label",
"public"."uk_625k_bedrock_geol_unit"."rank_uri",
"public"."uk_625k_bedrock_geol_unit"."rank_label",
"public"."uk_625k_bedrock_geol_unit"."cgi_ics_age_max_uri",
"public"."uk_625k_bedrock_geol_unit"."cgi_ics_age_min_uri",
"public"."UK_625K_BEDROCK_WGS84"."mfid" FOREIGN_ID_0_0
FROM "public"."uk_625k_bedrock_geol_unit"
INNER JOIN
ON
( "UK_625K_BEDROCK_WGS84"."lex_rcs" = "uk_625k_bedrock_geol_unit"."lex_rcs")
ORDER BY
"public"."UK_625K_BEDROCK_WGS84"."mfid" ASC,
"public"."uk_625k_bedrock_geol_unit"."lex_rcs" ASC,
CASE WHEN "UK_625K_BEDROCK_WGS84"."lex_rcs" = "uk_625k_bedrock_geol_unit"."lex_rcs" THEN 0 ELSE 1 END ASC, "public"."uk_625k_bedrock_geol_unit"."objectid"
This message (and any attachments) is for the recipient only. NERC is subject to the Freedom of Information Act 2000 and the contents of this email and any reply you make may be disclosed by NERC unless it is exempt from release under the Act. Any material supplied to NERC may be stored in an electronic records management system.
Hi Marcus,
Looks like a bug and I think I have an idea how to fix it. I'll have a look
next week.
https://jira.codehaus.org/browse/GEOT-4553
Rini
View this message in context: http://osgeo-org.1560.x6.nabble.com/app-schema-tries-to-access-non-existent-objectid-column-tp5074565p5075198.html
-----Original Message-----
From: Rini.Angreani@...367... [mailto:Rini.Angreani@…367…]
Sent: 06 September 2013 07:45
To: Sen, Marcus A.
Subject: RE: [Geoserver-users] app-schema tries to access non-existent
objectid column
Hi Marcus,
I checked in the fix into master and 2.4.x.
Please try the nightly build (these files don't exist yet, but should
be available tonight):
http://gridlock.opengeo.org/geoserver/2.4.x/geoserver-2.4.x-2013-09-07-
war.zip
http://gridlock.opengeo.org/geoserver/2.4.x/ext-2013-09-07/
Please let me know if the fix works or not.
It has worked, thanks :slight_smile:
Marcus
