[Geoserver-users] [AppFog Support] Re: Geoserver errors
Good afternoon!
Trying to install Geoserver on appfog.com, appfog has 2GB RAM and
tomcat6, JRE 1.7
Support wrote me:
"try modifying the soft java ulimit in the start command of your app,
our system ulimits are far higher that any application can handle on
there own."
I have a lot of "Too many open files"
Could you please take a look at it?
   http://thegeoserver.tk/web/
default login:
admin
geoserver
Thank you!!
All the best wishes!
Viktor
Idézem/Quoting Rich Howard <notifications-support@anonymised.com>:
# Please type your reply above this line #
Your request (#9726) has been deemed solved. To reopen, reply to
this email or follow the link below:
http://support.appfog.com/tickets/9726
Rich Howard, Jan 27 18:24 (PST)
Hi Viktor,
A) try modifying the soft java ulimit in the start command of your
app, our system ulimits are far higher that any application can
handle on there own.
B) The zipit tool was written as a quick and dirty way for PHP users
to collect data from PHP Fog and other PHP servers. There is no
Java solution provided by appfog.
Cheers and thank you for your questions!
-Rich, Customer Experience Manager, App Fog
www.appfog.com | www.phpfog.com
Viktor, Jan 27 15:15 (PST)
Good afternoon!
A)
After setting up a 1 instance/2 GB java app: Geoserver
it makes "Too many open files" errors:
/var/vcap.local/dea/apps/thegeoserver-0-e7605012b22bcb478da4379335b5af80/tomcat/webapps/ROOT/data/logs/geoserver.log (Too many
open
files)
How can I set ulimit higher?
You can login at http://thegeoserver.tk/web/
admin
geoserver
B)
I've read I have to write/use a function to save live filesystem.
There is an zipit in PHP.
Is there a Java solution?
Thank you very much!
Szépe Viktor
+36 20 4242498 sms@anonymised.com skype: szepe.viktor
Budapest, XIV. kerület, Róna utca 121.
This email is a service from AppFog Support
Szépe Viktor
Szépe Viktor
