[Geoserver-users] application/gml+xml; version=3.2
Hi List,
Looking at “layer preview” in 2.2.2, at the very bottom, as WFS there’s an entry that says:
“application/gml+xml; version=3.2”
if I click this I get:
java.lang.RuntimeException: No response: ( object = class org.geoserver.wfs.request.FeatureCollectionResponse$WFS11, outputFormat = application/gml xml; version=3.2 ) No response: ( object = class org.geoserver.wfs.request.FeatureCollectionResponse$WFS11, outputFormat = application/gml xml; version=3.2 )
It doesn’t seem to matter which layer I use it for. Would I be correct in thinking this is a bug, or is this some weird format that doesn’t like to work with regular data?
Also, wouldn’t that be GML3.2, in which case its in the list three entries higher (and works fine). Fairly sure its a bug, but figured I’d check before I reported it.
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
