[Geoserver-users] Application schema and DWithin operator support ?
I would like to use “DWithin” operator on features built by the application schema plugin.
Example :
<?xml version=``"1.0" encoding=``"UTF-8"``?>
<wfs:GetFeature
service=``"WFS"
version=``"2.0.0"
outputFormat=``"gml32"
xmlns:wfs=``"[http://www.opengis.net/wfs/2.0"](http://www.opengis.net/wfs/2.0)
xmlns:gml=``"[http://www.opengis.net/gml/3.2"](http://www.opengis.net/gml/3.2)
xmlns:fes=``"[http://www.opengis.net/fes/2.0"](http://www.opengis.net/fes/2.0)
xmlns:xsi=``"[http://www.w3.org/2001/XMLSchema-instance"](http://www.w3.org/2001/XMLSchema-instance)>
<wfs:Query typeName=``"myFeature"````>` fes:Filter ```<fes:DWithin>
<fes:ValueReference>geometryProperty``</fes:ValueReference>` <gml:LineString srsName="urn:ogc:def:crs:OGC:1.3:CRS84"> ```<gml:pos>-``32.5 52 -``31.5 53``</gml:pos>
</gml:LineString>` <fes:Distance uom="[NMI_I]">200</fes:Distance> ```</fes:DWithin>
</fes:Filter>` </wfs:Query> </wfs:GetFeature>`
So, “DWithin” operator is it fully supported by application schema plugin ?
Kind regards,
Rudy.
Rudy,
all spatial operators should be supported for app-schema as for non-app-schema. That said, I am not aware of any unit test coverage for this use-case. Please try it and report back if you encounter any unexpected behaviour.
Kind regards,
Ben.
On 12/07/13 21:32, Rudy Commenge wrote:
I would like to use "DWithin" operator on features built by the
Example :
|<?xml version=||"1.0"| |encoding=||"UTF-8"||?>|
|<wfs:GetFeature|
|service=||"WFS"|
|version=||"2.0.0"|
|outputFormat=||"gml32"|
|xmlns:wfs=||"http://www.opengis.net/wfs/2.0&quot;
<http://www.opengis.net/wfs/2.0&gt;|
|xmlns:gml=||"http://www.opengis.net/gml/3.2&quot;
<http://www.opengis.net/gml/3.2&gt;|
|xmlns:fes=||"http://www.opengis.net/fes/2.0&quot;
<http://www.opengis.net/fes/2.0&gt;|
|xmlns:xsi=||"http://www.w3.org/2001/XMLSchema-instance&quot;
<http://www.w3.org/2001/XMLSchema-instance&gt;&gt;|
|||<wfs:Query typeName=||"myFeature"||||>|
|||<fes:Filter>|
|||<fes:DWithin>|
|||<fes:ValueReference>geometryProperty||</fes:ValueReference>|
|||<gml:LineString srsName=||"urn:ogc:def:crs:OGC:1.3:CRS84"||>|
|||<gml:pos>-||32.5| |52| |-||31.5| |53||</gml:pos>|
|||</gml:LineString>|
|||<fes:Distance uom=||"[NMI_I]"||>||200||</fes:Distance>|
|||</fes:DWithin>|
|||</fes:Filter>|
|||</wfs:Query>|
|</wfs:GetFeature>|
So, "DWithin" operator is it fully supported by application schema plugin ?
Kind regards,
Rudy.
See everything from the browser to the database with AppDynamics
Get end-to-end visibility with application monitoring from AppDynamics
Isolate bottlenecks and diagnose root cause in seconds.
Start your free trial of AppDynamics Pro today!
http://pubads.g.doubleclick.net/gampad/clk?id=48808831&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
