Hello,
I have done some feature mapping with App-Schema. When I try to do wfs-query
with a bbox-parameter I get this message:
<ows:Exception exceptionCode="NoApplicableCode">
<ows:ExceptionText>java.lang.RuntimeException: Failed to get property:
{http://www.opengis.net/wfs/2.0\}boundedBy Failed to get property:
{http://www.opengis.net/wfs/2.0\}boundedBy java.io.IOException null ERROR:
syntax error at or near "FROM" Position: 618
</ows:ExceptionText>
</ows:Exception>
Without bbox the query works fine. I'm using Geoserver version 2.3.2 and
PostgreSQL 9.2.4 on Apache Tomcat/7.0.32-gentoo.
An example query is
server/geoserver/ows?service=WFS&version=2.0.0&request=GetFeature&typeNames=hy-p:Rapids&bbox=7009000,334000,7011000,335000.
I have tried with version 1.1.0, changing y- and x- coordinates, changing
srsname etc. Bbox-query works for the same data when not using app-schema
(using only database store). I have also configured layer.xml and
featuretype.xml in Rapids folder using tutorials and examples.
When I tried bbox-query with the App-Schema tutorial data, I didn't get any
errors, but didn't get any features either.
What could be wrong?
Best Regards,
Eero
View this message in context: http://osgeo-org.1560.x6.nabble.com/application-schema-and-wfs-query-with-bbox-tp5063574.html
