[Please keep discussions on-list]
Pu,
are your schemas in paths relative to the schemas/catalog.xml? Such as data_dir/schemas/cgiutilities/ ? Does GeoServer still complain about geosciml.org on startup?
I think you are missing several rewrite rules; I recommend one per host so I count four. According the contents of my app-schema-cache for the tutorial, the full list of dependencies is:
./net/opengis/schemas/gml/3.1.1/base/basicTypes.xsd
./net/opengis/schemas/gml/3.1.1/base/coordinateOperations.xsd
./net/opengis/schemas/gml/3.1.1/base/coordinateReferenceSystems.xsd
./net/opengis/schemas/gml/3.1.1/base/coordinateSystems.xsd
./net/opengis/schemas/gml/3.1.1/base/coverage.xsd
./net/opengis/schemas/gml/3.1.1/base/dataQuality.xsd
./net/opengis/schemas/gml/3.1.1/base/datums.xsd
./net/opengis/schemas/gml/3.1.1/base/defaultStyle.xsd
./net/opengis/schemas/gml/3.1.1/base/dictionary.xsd
./net/opengis/schemas/gml/3.1.1/base/direction.xsd
./net/opengis/schemas/gml/3.1.1/base/dynamicFeature.xsd
./net/opengis/schemas/gml/3.1.1/base/feature.xsd
./net/opengis/schemas/gml/3.1.1/base/geometryAggregates.xsd
./net/opengis/schemas/gml/3.1.1/base/geometryBasic0d1d.xsd
./net/opengis/schemas/gml/3.1.1/base/geometryBasic2d.xsd
./net/opengis/schemas/gml/3.1.1/base/geometryComplexes.xsd
./net/opengis/schemas/gml/3.1.1/base/geometryPrimitives.xsd
./net/opengis/schemas/gml/3.1.1/base/gml.xsd
./net/opengis/schemas/gml/3.1.1/base/gmlBase.xsd
./net/opengis/schemas/gml/3.1.1/base/grids.xsd
./net/opengis/schemas/gml/3.1.1/base/measures.xsd
./net/opengis/schemas/gml/3.1.1/base/observation.xsd
./net/opengis/schemas/gml/3.1.1/base/referenceSystems.xsd
./net/opengis/schemas/gml/3.1.1/base/temporal.xsd
./net/opengis/schemas/gml/3.1.1/base/temporalReferenceSystems.xsd
./net/opengis/schemas/gml/3.1.1/base/temporalTopology.xsd
./net/opengis/schemas/gml/3.1.1/base/topology.xsd
./net/opengis/schemas/gml/3.1.1/base/units.xsd
./net/opengis/schemas/gml/3.1.1/base/valueObjects.xsd
./net/opengis/schemas/gml/3.1.1/smil/smil20-language.xsd
./net/opengis/schemas/gml/3.1.1/smil/smil20.xsd
./net/opengis/schemas/ic/2.0/IC-ISM-v2.xsd
./net/opengis/schemas/om/1.0.0/observation.xsd
./net/opengis/schemas/om/1.0.0/om.xsd
./net/opengis/schemas/sampling/1.0.0/LUTgeodesy.xsd
./net/opengis/schemas/sampling/1.0.0/sampling.xsd
./net/opengis/schemas/sampling/1.0.0/samplingBase.xsd
./net/opengis/schemas/sampling/1.0.0/samplingManifold.xsd
./net/opengis/schemas/sampling/1.0.0/specimen.xsd
./net/opengis/schemas/sampling/1.0.0/surveyProcedure.xsd
./net/opengis/schemas/sensorML/1.0.1/base.xsd
./net/opengis/schemas/sensorML/1.0.1/method.xsd
./net/opengis/schemas/sensorML/1.0.1/process.xsd
./net/opengis/schemas/sensorML/1.0.1/sensorML.xsd
./net/opengis/schemas/sensorML/1.0.1/system.xsd
./net/opengis/schemas/sweCommon/1.0.1/aggregateTypes.xsd
./net/opengis/schemas/sweCommon/1.0.1/basicTypes.xsd
./net/opengis/schemas/sweCommon/1.0.1/curveTypes.xsd
./net/opengis/schemas/sweCommon/1.0.1/data.xsd
./net/opengis/schemas/sweCommon/1.0.1/encoding.xsd
./net/opengis/schemas/sweCommon/1.0.1/phenomenon.xsd
./net/opengis/schemas/sweCommon/1.0.1/positionTypes.xsd
./net/opengis/schemas/sweCommon/1.0.1/simpleTypes.xsd
./net/opengis/schemas/sweCommon/1.0.1/swe.xsd
./net/opengis/schemas/sweCommon/1.0.1/temporalAggregates.xsd
./net/opengis/schemas/sweCommon/1.0.1/xmlData.xsd
./org/geosciml/www/cgiutilities/1.0/xsd/cgiUtilities.xsd
./org/geosciml/www/cgiutilities/1.0/xsd/primitiveTypes.xsd
./org/geosciml/www/geosciml/2.0/xsd/borehole.xsd
./org/geosciml/www/geosciml/2.0/xsd/collection.xsd
./org/geosciml/www/geosciml/2.0/xsd/earthMaterial.xsd
./org/geosciml/www/geosciml/2.0/xsd/fossil.xsd
./org/geosciml/www/geosciml/2.0/xsd/geologicAge.xsd
./org/geosciml/www/geosciml/2.0/xsd/geologicFeature.xsd
./org/geosciml/www/geosciml/2.0/xsd/geologicRelation.xsd
./org/geosciml/www/geosciml/2.0/xsd/geologicStructure.xsd
./org/geosciml/www/geosciml/2.0/xsd/geologicUnit.xsd
./org/geosciml/www/geosciml/2.0/xsd/geosciml.xsd
./org/geosciml/www/geosciml/2.0/xsd/value.xsd
./org/geosciml/www/geosciml/2.0/xsd/vocabulary.xsd
./org/w3/www/1999/xlink.xsd
Kind regards,
Ben.
On 17/07/13 12:23, LIN Pu wrote:
Hi Ben,
I used the OASIS catalog but still got the error message. Did I miss something?
1 Add the element <catalog>../../../schemas/catalog.xml</catalog> to gsml_GeologicUnit.xml.
2. Add schemas under data_dir.
3. catalog.xml
<?xml version="1.0"?>
<!DOCTYPE catalog PUBLIC
"-//OASIS//DTD Entity Resolution XML Catalog V1.0//EN"
"http://www.oasis-open.org/committees/entity/release/1.0/catalog.dtd">
<catalog xmlns="urn:oasis:names:tc:entity:xmlns:xml:catalog">
<rewriteURI uriStartString="http://www.geosciml.org/cgiutilities/"
rewritePrefix="cgiutilities/" />
<rewriteURI uriStartString="http://www.geosciml.org/geosciml/"
rewritePrefix="geosciml/" />
<rewriteURI uriStartString="http://schemas.opengis.net/sampling/"
rewritePrefix="sampling/" />
</catalog>
Pu Lin
-----Original Message-----
From: Ben Caradoc-Davies [mailto:Ben.Caradoc-Davies@anonymised.com]
Sent: Wednesday, 17 July 2013 12:42 PM
To: LIN Pu
Subject: Re: [Geoserver-users] application schema error
Pu Lin,
does your machine have internet access?
If you are behind a firewall that prevents outgoing web connections, GeoServer app-schema will not be able to download the GML application schemas that define the GeoSciML information model, and data store initialisation will fail. This download only occurs the first time GeoServer app-schema starts; schemas are cached for future use in the folder app-schema-cache in your data directory.
There are several solutions to this problem, documented at the end of this page:
http://docs.geoserver.org/latest/en/user/data/app-schema/app-schema-resolution.html
Also, if you are able to make outgoing HTTP requests on port 80 using a web proxy, you should also be able to configure your JRE to use this proxy. I have not tried it as I do not use Windows, but here is the Java support page:
http://www.java.com/en/download/help/proxy_setup.xml
Kind regards,
Ben.
On 17/07/13 09:03, Pu Lin wrote:
I had the similar problem. I followed the instructions to install
Geoserver2.3.3, application schema and tutorial data on Windows 7
(64), JRE6 (32). When I enter the following url
"http://localhost:8080/geoserver/wfs?request=GetFeature&version=1.1.0&
typeName=gsml:GeologicUnit",
the error message is
<?xml version="1.0" encoding="UTF-8" ?>
- <ows:ExceptionReport version="1.0.0"
xsi:schemaLocation="http://www.opengis.net/ows
http://localhost:8080/geoserver/schemas/ows/1.0.0/owsExceptionReport.xsd"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ows="http://www.opengis.net/ows">
- <ows:Exception exceptionCode="NoApplicableCode">
<ows:ExceptionText>Error occurred getting features null
java.net.UnknownHostException: www.geosciml.org
www.geosciml.org</ows:ExceptionText>
</ows:Exception>
</ows:ExceptionReport>
The server log has "Error connecting to 'gsml_GeologicUnit'. Disabling:.
Pu Lin
View this message in context:
http://osgeo-org.1560.x6.nabble.com/application-schema-error-tp5045388
p5066904.html Sent from the GeoServer - User mailing list archive at
Nabble.com.
-------- See everything from the browser to the database with
AppDynamics Get end-to-end visibility with application monitoring from
AppDynamics Isolate bottlenecks and diagnose root cause in seconds.
Start your free trial of AppDynamics Pro today!
http://pubads.g.doubleclick.net/gampad/clk?id=48808831&iu=/4140/ostg.c
lktrk _______________________________________________
Geoserver-users mailing list
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com> Software Engineer CSIRO Earth Science and Resource Engineering Australian Resources Research Centre
The information in this email together with any attachments is intended only for the person or entity to which it is addressed and may contain confidential and/or privileged material. There is no waiver of any confidentiality/privilege by your inadvertent receipt of this material.
Any form of review, disclosure, modification, distribution and/or publication of this email message is prohibited, unless as a necessary part of Departmental business.
If you have received this message in error, you are asked to inform the sender as quickly as possible and delete this message and any copies of this message from your computer and/or your computer system network.
Software Engineer
