[Geoserver-users] ArcGIS 9.3.1 Geoserver Secured Layer GetFeatureInfo problem
Hi List,
Does anybody have any idea, why ArcGIS ArcMap 9.3.1 does not display the feature info, when a layer is secured?
The QGis and the ArcGIS 10.1 displays the featureinfo html without any problems.
Anybody have experience with it?
Thanks a lot!
Zsolt, Magyar
http://support.esri.com/es/knowledgebase/techarticles/detail/27952 - maybe?
On 7 March 2013 14:05, Zsolt Magyar <zmagyar77@anonymised.com> wrote:
Hi List,
Thanks a lot!
Zsolt, Magyar
Symantec Endpoint Protection 12 positioned as A LEADER in The Forrester
Wave™: Endpoint Security, Q1 2013 and “remains a good choice” in the
endpoint security space. For insight on selecting the right partner to
tackle endpoint security challenges, access the full report.
http://p.sf.net/sfu/symantec-dev2dev
Geoserver-users mailing list
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
Thanks Jonathan!
I’ll try the Sp2 on ArcGis 9.3.1.
Thanks again!
Zsolt
2013/3/7 Jonathan Moules <jonathanmoules@anonymised.com>
Hi List,
Thanks a lot!
Zsolt, Magyar
Geoserver-users@anonymised.coms.sourceforge.net
Beyond the Service Pack 2 all kind of patches should be installed for WMS getFeatureInfo.
Thanks for tip again!
Zsolt
2013/3/7 Zsolt Magyar <zmagyar77@anonymised.com>
Thanks Jonathan!
Thanks again!
Zsolt
Hi List,
Thanks a lot!
Zsolt, Magyar
No Problem. God forbid ESRI implement a standard fully and without their own quirks. :slight_smile:
Jonathan
Zsolt
Thanks Jonathan!
Thanks again!
Zsolt
Hi List,
Thanks a lot!
Zsolt, Magyar
