[Geoserver-users] ArcGIS + SLD
I’m using ARcgis 9.0 and i want to convert shapefiles to sld.
I already know arcmap2sld converter but this program doesnt convert complexes styles.
For example it doesnt convert pictures or fil symbols.
The program only convert simple styles, with simple lines.
Anybody knows another editor?
Fernando Quadro
Laboratório de Computação Aplicada - UNIVALI - Brasil
fsquadro@anonymised.com95…
Busque em qualquer página da Web com alta proteção. Obtenha o Windows Live Toolbar GRATUITO ainda hoje! Experimente agora!
OpenJUMP (www.openjump.org) is among other things an Open source shapefile editor that can export styles as SLD. I had never before tried this functionality but I just made a test and it at least it is dead easy to use. Just open the shapefile, use 'Change styles' tool to make the map look as you want and store the style as SLD by using 'Transform layer style into SLD' option. Perhaps a bit unlogically, it is under 'View' menu. If you are going to try OpenJUMP then I recommend you to download the nightly build because it has much more than the release. Nothing SLD related, though.
-Jukka Rahkonen-
Lähettäjä: geoserver-users-bounces@lists.sourceforge.net puolesta: Fernando Quadro
Lähetetty: to 22.3.2007 20:07
Vastaanottaja: geoserver-users@lists.sourceforge.net; geoserver-devel@anonymised.com.sourceforge.net
Aihe: [Geoserver-users] ArcGIS + SLD
I'm using ARcgis 9.0 and i want to convert shapefiles to sld.
Fernando Quadro
Busque em qualquer página da Web com alta proteção. Obtenha o Windows Live Toolbar GRATUITO ainda hoje! Experimente agora! <http://toolbar.live.com/&gt;
