Hi
I use a stand-alone version of GeoWebCache I compiled with the ability to display ArcGIS compact caches (ArcGISLayer). I deployed this version on a TomCat. But I can not deployed on the same TomCat an instance of GeoServer with an embedded version of GeoWebCache : there is a conflict with the non-integrated version (GeoWebCache.xml contains section not compatible).
Ideally for me GeoServer should integrate a version of GeoWebCache including the reading of ArcGIS compact cache. Is such a solution proposed in the roadmap?
Otherwise how to replace the embedded version of GeoWebCache with another?
xavier lhomme
