[Geoserver-users] arcsde and not spatial tables
Done:
http://jira.codehaus.org/browse/GEOS-1817
TIA.
Best regards,
Bart
Bart van den Eijnden
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: Gabriel Roldán <groldan@anonymised.com>
Naar: Andrea Aime <aaime@anonymised.com>
Cc: Bart van den Eijnden OSGIS <bartvde@anonymised.com>,
geoserver-users@lists.sourceforge.net
Onderwerp: Re: [Geoserver-users] arcsde and not spatial tables
Datum: 19/03/08 12:54
catching up on email.
Right, non spatial tables are not supported by the ArcSDE geotools plugin,
but
supporting at least the sde registered tables would be quite easy I guess
and
the appropriate way to indicate which ones to show and what not
(registering
a table/view with sde works more or less like the postgis geometry_columns
table)
Bart, could you add a jira issue for this?
regards,
Gabriel
On Monday 17 March 2008 02:26:44 pm Andrea Aime wrote:
&gt; Bart van den Eijnden (OSGIS) ha scritto:
&gt; &gt; Hi list,
&gt; &gt;
&gt; &gt; we've been trying to access a non-spatial table (ArcCatalog
calls this a
&gt; &gt; SDE Table) through Geoserver-ArcSDE, but when choosing New
FeatureType it
&gt; &gt; does not show up in the list. Is there some kind of check in the
ArcSDE
&gt; &gt; driver that filters for this?
&gt; &gt;
&gt; &gt; When using the &quot;raw&quot; OCI connection, we do get the
table, but ofcourse it
&gt; &gt; would be best to reference everything through ArcSDE.
&gt; &gt;
&gt; &gt; Is this a known caveat? TIA.
&gt;
&gt; Generally speaking non geographic data serving in GeoTools data store
&gt; came as an afterthought, and fixing a datastore so that it can deal
&gt; with data without geometries is not always easy. Many datastores
&gt; were in fact coded so that non geometric tables weren't available
&gt; because they did not make sense in a GIS setting.
&gt; Afterwards some datastores were fixed to work with geometryless
&gt; data as well, I guess ArcSDE is not among the lot.
&gt; Probably Gabriel can provide more information about this.
&gt; Gabriel?
&gt;
&gt; Cheers
&gt; Andrea
&gt;
&gt; !DSPAM:4045,47de71a951511804284693!
