Hi list,
i still don’t get a connection to my ArcSDE backend. I tried some time ago and posted my problems, but there were no solution for the exception until now. Maybe there are some new awarenesses about this exception. Here’s the exception i get, when i try to connect to the arcsde backend:
21 Apr 15:15:07 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/config/data/” “Mozilla/5.0 (Windows; U; Windows NT 5.1; de; rv:1.8.1.14) Gecko/20080404 Firefox/2.0.0.14” “”
21 Apr 15:15:07 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/config/data/” took 0ms
21 Apr 15:15:14 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/” “Mozilla/5.0 (Windows; U; Windows NT 5.1; de; rv:1.8.1.14) Gecko/20080404 Firefox/2.0.0.14” “”
21 Apr 15:15:14 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/” took 63ms
21 Apr 15:15:14 INFO [geoserver.filters] - Compressing output for mimetype: text/html
21 Apr 15:15:14 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/gs.ico” “Mozilla/5.0 (Windows; U; Windows NT 5.1; de; rv:1.8.1.14) Gecko/20080404 Firefox/2.0.0.14” “”
21 Apr 15:15:14 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/gs.ico” took 0ms
21 Apr 15:15:14 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/welcome.do” “Mozilla/5.0 (Windows; U; Windows NT 5.1; de; rv:1.8.1.14) Gecko/20080404 Firefox/2.0.0.14” “http://localhost:8080/geoserver/”
21 Apr 15:15:14 INFO [tiles.TilesRequestProcessor] - Tiles definition factory found for request processor ‘’.
21 Apr 15:15:14 INFO [geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
21 Apr 15:15:14 WARN [geoserver.filters] - Setting mimetype after acquiring stream! was:text/html;charset=UTF-8; set to: text/html; url was: http://localhost:8080/geoserver/welcome.do
21 Apr 15:15:14 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/welcome.do” took 312ms
21 Apr 15:15:18 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/config/index.do” “Mozilla/5.0 (Windows; U; Windows NT 5.1; de; rv:1.8.1.14) Gecko/20080404 Firefox/2.0.0.14” “http://localhost:8080/geoserver/welcome.do”
21 Apr 15:15:18 INFO [geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
21 Apr 15:15:18 WARN [geoserver.filters] - Setting mimetype after acquiring stream! was:text/html;charset=UTF-8; set to: text/html; url was: http://localhost:8080/geoserver/config/index.do
21 Apr 15:15:18 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/config/index.do” took 47ms
21 Apr 15:15:18 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/images/gs.gif” “Mozilla/5.0 (Windows; U; Windows NT 5.1; de; rv:1.8.1.14) Gecko/20080404 Firefox/2.0.0.14” “”
21 Apr 15:15:18 INFO [geoserver.filters] - Not compressing output for mimetype: image/gif
21 Apr 15:15:18 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/images/gs.gif” took 0ms
21 Apr 15:15:19 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/config/data/index.do” “Mozilla/5.0 (Windows; U; Windows NT 5.1; de; rv:1.8.1.14) Gecko/20080404 Firefox/2.0.0.14” “http://localhost:8080/geoserver/config/index.do”
21 Apr 15:15:19 INFO [geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
21 Apr 15:15:19 WARN [geoserver.filters] - Setting mimetype after acquiring stream! was:text/html;charset=UTF-8; set to: text/html; url was: http://localhost:8080/geoserver/config/data/index.do
21 Apr 15:15:19 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/config/data/index.do” took 78ms
21 Apr 15:15:19 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/images/gs.gif” “Mozilla/5.0 (Windows; U; Windows NT 5.1; de; rv:1.8.1.14) Gecko/20080404 Firefox/2.0.0.14” “”
21 Apr 15:15:19 INFO [geoserver.filters] - Not compressing output for mimetype: image/gif
21 Apr 15:15:19 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/images/gs.gif” took 0ms
21 Apr 15:15:21 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/config/data/store.do” “Mozilla/5.0 (Windows; U; Windows NT 5.1; de; rv:1.8.1.14) Gecko/20080404 Firefox/2.0.0.14” “http://localhost:8080/geoserver/config/data/index.do”
21 Apr 15:15:21 INFO [geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
21 Apr 15:15:21 WARN [geoserver.filters] - Setting mimetype after acquiring stream! was:text/html;charset=UTF-8; set to: text/html; url was: http://localhost:8080/geoserver/config/data/store.do
21 Apr 15:15:21 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/config/data/store.do” took 63ms
21 Apr 15:15:21 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/images/gs.gif” “Mozilla/5.0 (Windows; U; Windows NT 5.1; de; rv:1.8.1.14) Gecko/20080404 Firefox/2.0.0.14” “”
21 Apr 15:15:21 INFO [geoserver.filters] - Not compressing output for mimetype: image/gif
21 Apr 15:15:21 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/images/gs.gif” took 0ms
21 Apr 15:15:23 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/config/data/storeNew.do” “Mozilla/5.0 (Windows; U; Windows NT 5.1; de; rv:1.8.1.14) Gecko/20080404 Firefox/2.0.0.14” “http://localhost:8080/geoserver/config/data/store.do”
21 Apr 15:15:23 INFO [geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
21 Apr 15:15:23 WARN [geoserver.filters] - Setting mimetype after acquiring stream! was:text/html;charset=UTF-8; set to: text/html; url was: http://localhost:8080/geoserver/config/data/storeNew.do
21 Apr 15:15:23 DEBUG [geotools.arcsde] - com.esri.sde.sdk.client.SeConnection is in place.
21 Apr 15:15:23 DEBUG [geotools.arcsde] - com.esri.sde.sdk.pe.PeCoordinateSystem is in place.
21 Apr 15:15:23 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/config/data/storeNew.do” took 47ms
21 Apr 15:15:23 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/images/gs.gif” “Mozilla/5.0 (Windows; U; Windows NT 5.1; de; rv:1.8.1.14) Gecko/20080404 Firefox/2.0.0.14” “”
21 Apr 15:15:23 INFO [geoserver.filters] - Not compressing output for mimetype: image/gif
21 Apr 15:15:23 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/images/gs.gif” took 0ms
21 Apr 15:15:28 INFO [geoserver.filters] - 127.0.0.1 “POST /geoserver/config/data/storeNewSubmit.do” “Mozilla/5.0 (Windows; U; Windows NT 5.1; de; rv:1.8.1.14) Gecko/20080404 Firefox/2.0.0.14” “http://localhost:8080/geoserver/config/data/storeNew.do”
21 Apr 15:15:28 DEBUG [geotools.arcsde] - com.esri.sde.sdk.client.SeConnection is in place.
21 Apr 15:15:28 DEBUG [geotools.arcsde] - com.esri.sde.sdk.pe.PeCoordinateSystem is in place.
21 Apr 15:15:28 INFO [geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
21 Apr 15:15:28 WARN [geoserver.filters] - Setting mimetype after acquiring stream! was:text/html;charset=UTF-8; set to: text/html; url was: http://localhost:8080/geoserver/config/data/storeNewSubmit.do
21 Apr 15:15:28 INFO [geoserver.filters] - 127.0.0.1 “POST /geoserver/config/data/storeNewSubmit.do” took 78ms
21 Apr 15:15:28 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/images/gs.gif” “Mozilla/5.0 (Windows; U; Windows NT 5.1; de; rv:1.8.1.14) Gecko/20080404 Firefox/2.0.0.14” “”
21 Apr 15:15:28 INFO [geoserver.filters] - Not compressing output for mimetype: image/gif
21 Apr 15:15:28 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/images/gs.gif” took 0ms
21 Apr 15:15:53 INFO [geoserver.filters] - 127.0.0.1 “POST /geoserver/config/data/storeSubmit.do” “Mozilla/5.0 (Windows; U; Windows NT 5.1; de; rv:1.8.1.14) Gecko/20080404 Firefox/2.0.0.14” “http://localhost:8080/geoserver/config/data/storeNewSubmit.do”
form connection params { password=“nBn5.AtR”, pool.minConnections=2, user=“natur”, instance=“esri_sde”, pool.maxConnections=2, pool.timeOut=1000, server=“geointra1.ulf.hessen.de”, port=5151, dbtype=“arcsde”}
21 Apr 15:15:53 DEBUG [geotools.arcsde] - com.esri.sde.sdk.client.SeConnection is in place.
21 Apr 15:15:53 DEBUG [geotools.arcsde] - com.esri.sde.sdk.pe.PeCoordinateSystem is in place.
21 Apr 15:15:53 DEBUG [pool.ArcSDEConnectionPool] - populating ArcSDE connection pool
21 Apr 15:15:53 INFO [pool.ArcSDEConnectionPool] - Created ArcSDE connection pool for org.geotools.arcsde.pool.ArcSDEConnectionConfig[dbtype=arcsde, server=geointra1.ulf.hessen.de, port=5151, instance=esri_sde, user=natur, password=*****, minConnections=2, maxConnections=2, connTimeOut=1000]
21 Apr 15:15:54 TRACE [pool.ArcSDEConnectionPool] - activating connection org.geotools.arcsde.pool.ArcSDEPooledConnection@anonymised.com
21 Apr 15:15:54 TRACE [pool.ArcSDEConnectionPool] - Validating SDE Connection
21 Apr 15:15:54 DEBUG [pool.ArcSDEConnectionPool] - Connection validated, returned user NATUR
21 Apr 15:15:55 TRACE [pool.ArcSDEConnectionPool] - Validating SDE Connection
21 Apr 15:15:55 WARN [geoserver.action] - Unable to fetch a list of FeatureType names from datastore.
java.lang.OutOfMemoryError: Java heap space
at com.esri.sde.sdk.client.s$a_.o(Unknown Source)
at com.esri.sde.sdk.client.s$a_.f(Unknown Source)
at com.esri.sde.sdk.client.s.n(Unknown Source)
at com.esri.sde.sdk.client.b.k(Unknown Source)
at com.esri.sde.sdk.client.SeConnection.getUser(Unknown Source)
at org.geotools.arcsde.pool.ArcSDEConnectionPool$SeConnectionFactory.validateObject(ArcSDEConnectionPool.java:594)
at org.apache.commons.pool.impl.GenericObjectPool.addObjectToPool(GenericObjectPool.java:922)
at org.apache.commons.pool.impl.GenericObjectPool.returnObject(GenericObjectPool.java:917)
at org.geotools.arcsde.pool.ArcSDEPooledConnection.close(ArcSDEPooledConnection.java:62)
at org.geotools.arcsde.pool.ArcSDEConnectionPool.getAvailableLayerNames(ArcSDEConnectionPool.java:413)
at org.geotools.arcsde.data.ArcSDEDataStore.getTypeNames(ArcSDEDataStore.java:168)
at org.vfny.geoserver.util.DataStoreUtils.getDataStore(DataStoreUtils.java:66)
at org.vfny.geoserver.util.DataStoreUtils.acquireDataStore(DataStoreUtils.java:51)
at org.vfny.geoserver.action.data.DataDataStoresEditorAction.execute(DataDataStoresEditorAction.java:134)
at org.vfny.geoserver.action.ConfigAction.execute(ConfigAction.java:101)
at org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:431)
at org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:236)
at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1196)
at org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:432)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:710)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:269)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:188)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:215)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:69)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
21 Apr 15:15:55 INFO [geoserver.filters] - Compressing output for mimetype: text/html;charset=UTF-8
21 Apr 15:15:55 WARN [geoserver.filters] - Setting mimetype after acquiring stream! was:text/html;charset=UTF-8; set to: text/html; url was: http://localhost:8080/geoserver/config/data/storeSubmit.do
21 Apr 15:15:55 INFO [geoserver.filters] - 127.0.0.1 “POST /geoserver/config/data/storeSubmit.do” took 2797ms
21 Apr 15:15:55 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/images/gs.gif” “Mozilla/5.0 (Windows; U; Windows NT 5.1; de; rv:1.8.1.14) Gecko/20080404 Firefox/2.0.0.14” “”
21 Apr 15:15:55 INFO [geoserver.filters] - Not compressing output for mimetype: image/gif
21 Apr 15:15:55 INFO [geoserver.filters] - 127.0.0.1 “GET /geoserver/images/gs.gif” took 0ms
The problem is: I set the java heap space up to 512 MB. This cannot be the problem. I think its a standard error message if nothing else fits.
The ArcSDE client api was said to be correctly found and used. But what else can be wrong? I’m using the 1.6.3 with a nightly build from 2 weeks ago of the “gt2-arcsde-2.4-SNAPSHOT.jar”. I hope somebody can help me.
Regards
Albrecht
