Some more info, WMS keeps on working fine, whereas WFS-T support breaks
after a few (about 10) transactions, even after increasing the timeout to
10000.
I also get a lot of broken pipe errors:
2008-02-20 16:59:58,034 INFO [org.geotools.arcsde.pool.ArcSDEConnectionPool]
- Can't validate SeConnection, discarding it:
org.geotools.arcsde.pool.ArcSDEPooledConnection@anonymised.com
2008-02-20 16:59:58,035 INFO [org.geotools.arcsde.pool] - closing
connection: Broken pipe
2008-02-20 16:59:58,036 WARN [org.geoserver.ows] -
java.lang.IndexOutOfBoundsException
at
java.io.ByteArrayInputStream.read(ByteArrayInputStream.java(Compiled Code))
at java.io.DataInputStream.read(DataInputStream.java(Inlined
Compiled Code))
at com.esri.sde.sdk.client.r$a_.a(Unknown Source)
at com.esri.sde.sdk.client.r$a_.l(Unknown Source)
at com.esri.sde.sdk.client.r$a_.b(Unknown Source)
at com.esri.sde.sdk.client.r.j(Unknown Source)
at com.esri.sde.sdk.client.b.h(Unknown Source)
at com.esri.sde.sdk.client.b.o(Unknown Source)
at com.esri.sde.sdk.client.j.a(Unknown Source)
at com.esri.sde.sdk.client.SeQuery.calculateTableStatistics(Unknown
Source)
at
org.geotools.arcsde.data.ArcSDEQuery.calculateResultCount(ArcSDEQuery.java:632)
at
org.geotools.arcsde.data.ArcSDEQuery.calculateResultCount(ArcSDEQuery.java:543)
at
org.geotools.arcsde.data.ArcSDEDataStore.getCount(ArcSDEDataStore.java:996)
at
org.geotools.data.AbstractFeatureSource.getCount(AbstractFeatureSource.java:310)
at
org.geotools.data.DefaultFeatureResults.getCount(DefaultFeatureResults.java:295)
at
org.geotools.data.store.DataFeatureCollection.size(DataFeatureCollection.java:282)
at
org.geotools.data.crs.ForceCoordinateSystemFeatureResults.size(ForceCoordinateSystemFeatureResults.java:122)
at org.geoserver.wfs.GetFeature.run(GetFeature.java:254)
at
org.geoserver.wfs.DefaultWebFeatureService.getFeature(DefaultWebFeatureService.java:108)
at sun.reflect.GeneratedMethodAccessor154.invoke(Unknown Source)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java(Compiled
Code))
at java.lang.reflect.Method.invoke(Method.java(Compiled Code))
at
org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:292)
at
org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:155)
Best regards,
Bart
Bart van den Eijnden
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: Bart van den Eijnden OSGIS <bartvde@anonymised.com>
Naar: Gabriel Roldán <groldan@anonymised.com>,
geoserver-users@lists.sourceforge.net
<geoserver-users@lists.sourceforge.net>, Bart van den Eijnden OSGIS
Cc: Saul Farber <Saul.Farber@anonymised.com>
Onderwerp: Re: [Geoserver-users] ArcSDE connection pooling issues
Datum: 20/02/08 13:49
Hi Gabriel,
the OL layers are WFS layers, so Untiled. There are only 3 layers (one for
points, polygons and lines) in the application, and using OpenLayers
(Layer.WFS) new features are added.So we don't use WMS, only WFS in this case.
I have the default value for the connection timeout, I'll try increasing
it.
Best regards,
Bart--
http://www.osgis.nl--------- Oorspronkelijk bericht --------
Van: Gabriel Roldán <groldan@anonymised.com>
Naar: geoserver-users@lists.sourceforge.net
Datum: 20/02/08 13:41> Hi Bart,
> My first thought is it may be a matter of balance bettween connection
pool
> size and pool's connTimeout argument. Did you try increasing the
connTimeout
> parameter in the DataStore config?
> question though: is the openlayers client requesting tiles? I've to
admit
I
> never tried a tiling client over arcsde layers myself, but it would
make
> sense to run out of connections depending on the ammount of tiles
being
> requested at a time and the ammount of layers composing the map.
> Yet its though. I've been trying Saul's massgis WMS[1] through uDig
before
> replying to this message and it seems to perform well even requesting
20
> layers at a time.
> May be Saul (cc'ed) can give us a couple clues about how to set up a
> production geoserver backed up by arcsde?
> Saul: did you ever run into connection exhaustion issues with your
server
and,
> if so, how did you solved them? is it just a matter of having a ton
of
> available connections? and did you ever tried hitting it with a
tiling
> client?
> cheers,
> Gabriel
> [1]Massgis WMS server:
> On Wednesday 20 February 2008 02:20:39 pm Bart van den Eijnden
(OSGIS)
wrote:
> &gt; Hi list,
> &gt;
> &gt; we are running into connection pooling issues (using
1.6RC2), we now
have
> &gt; even increased the maximum number up to 25 (coming from 8),
but still
> &gt; Geoserver runs out of connections after a while. There is
only 1
client
> &gt; (OpenLayers based) active!
> &gt;
> &gt; What could be the issue?
> &gt;
> &gt; Caused by: java.util.NoSuchElementException: Could not
aquire
> &gt; feature:org.geotools.data.DataSourceException: The maximun
of 25 to
> &gt;
org.geotools.arcsde.pool.ArcSDEConnectionConfig[dbtype=arcsde,
> &gt; server=geodatabase.ad.rws.nl, port=5151, instance=null,
user=DID,
> &gt; password=*****, minConnections=2, maxConnections=25,
connTimeOut=1000] has
> &gt; been reached
> &gt;
> &gt; 2008-02-20 11:17:03,298 WARN
> &gt; [org.geotools.arcsde.pool.ArcSDEConnectionPool] - Out of
connections:
> &gt; Timeout waiting for idle object
> &gt; java.util.NoSuchElementException: Timeout waiting for idle
object
> &gt; at
> &gt;
org.apache.commons.pool.impl.GenericObjectPool.borrowObject(GenericObjectPo
> &gt;ol.java(Compiled Code))
> &gt; at
> &gt;
org.geotools.arcsde.pool.ArcSDEConnectionPool.getConnection(ArcSDEConnectio
> &gt;nPool.java(Compiled Code))
> &gt; at
> &gt;
org.geotools.arcsde.data.ArcSDEDataStore.getFeatureWriterAppend(ArcSDEDataS
> &gt;tore.java:963) at
> &gt;
org.geotools.data.AbstractFeatureStore.addFeatures(AbstractFeatureStore.jav
> &gt;a:249) at
> &gt;
org.vfny.geoserver.global.GeoServerFeatureStore.addFeatures(GeoServerFeatur
> &gt;eStore.java:76) at
> &gt;
org.geoserver.wfs.InsertElementHandler.execute(InsertElementHandler.java:16
> &gt;4) at
org.geoserver.wfs.Transaction.execute(Transaction.java:328) at
> &gt;
org.geoserver.wfs.Transaction.transaction(Transaction.java:104) at
> &gt;
org.geoserver.wfs.DefaultWebFeatureService.transaction(DefaultWebFeatureSer
> &gt;vice.java:156) at
sun.reflect.GeneratedMethodAccessor203.invoke(Unknown
> &gt; Source) at
> &gt;
> &gt;l.java(Compiled Code))
> &gt; at
Code))
> &gt; at
> &gt;
> &gt;Utils.java:292) at
> &gt;
> &gt;t(ReflectiveMethodInvocation.java:155) at
> &gt;
org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(Reflec
> &gt;tiveMethodInvocation.java:122) at
> &gt; org.geoserver.wfs.WFSLogger.invoke(WFSLogger.java:44)
> &gt; at
> &gt;
> &gt;tiveMethodInvocation.java:144) at
> &gt;
org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopPr
> &gt;oxy.java:174) at $Proxy0.transaction(Unknown Source)
> &gt; at
sun.reflect.GeneratedMethodAccessor306.invoke(Unknown
Source)
> &gt; at
> &gt;
> &gt; at
Code))
> &gt; at
> &gt;
org.geoserver.security.OperationSecurityInterceptor.invoke(OperationSecurit
> &gt;yInterceptor.java:41) at
> &gt; org.geoserver.ows.Dispatcher.execute(Dispatcher.java:495) at
> &gt;
org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:188)
> &gt; at
> &gt;
org.springframework.web.servlet.mvc.AbstractController.handleRequest(Abstra
> &gt;ctController.java:139) at
> &gt;
org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(S
> &gt;impleControllerHandlerAdapter.java:44) at
> &gt;
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServ
> &gt;let.java:684) at
> &gt;
org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServl
> &gt;et.java:625) at
> &gt;
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkSe
> &gt;rvlet.java:392) at
> &gt;
org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.ja
> &gt;va:357) at
javax.servlet.http.HttpServlet.service(HttpServlet.java:709) at
> &gt;
javax.servlet.http.HttpServlet.service(HttpServlet.java(Compiled
Code))
> &gt; at
> &gt;
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(Applicatio
> &gt;nFilterChain.java(Compiled Code))
> &gt; at
> &gt;
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterC
> &gt;hain.java(Compiled Code))
> &gt; at
> &gt;
org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacter
> &gt;EncodingFilter.java:108) at
> &gt;
> &gt; at
> &gt;
> &gt; at
> &gt;
org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterC
> &gt;hainProxy.java(Compiled Code))
> &gt; at
> &gt;
org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecu
> &gt;rityInterceptor.java:107) at
> &gt;
org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSe
> &gt;curityInterceptor.java:72) at
> &gt;
> &gt; at
> &gt;
org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslati
> &gt;onFilter.java:110) at
> &gt;
> &gt; at
> &gt;
org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(An
> &gt;onymousProcessingFilter.java:125) at
> &gt;
> &gt; at
> &gt;
org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessi
> &gt;ngFilter.java:178) at
> &gt;
> &gt; at
> &gt;
org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(Http
> &gt;SessionContextIntegrationFilter.java:229) at
> &gt;
> &gt; at
> &gt;
org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
> &gt; at
> &gt;
org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98
> &gt;) at
> &gt;
> &gt; at
> &gt;
> &gt; at
> &gt;
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.j
> &gt;ava:213) at
> &gt;
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.j
> &gt;ava:178) at
> &gt;
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:12
> &gt;6) at
> &gt;
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:10
> &gt;5) at
> &gt;
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.jav
> &gt;a:107) at
> &gt;
org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:526)
> &gt; at
> &gt;
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:148)
> &gt; at
> &gt;
org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:856)
> &gt; at
> &gt;
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.processConn
> &gt;ection(Http11Protocol.java:744) at
> &gt;
org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(PoolTcpEndpoint.ja
> &gt;va:527) at
> &gt;
org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt(LeaderFollowerW
> &gt;orkerThread.java:80) at
> &gt;
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.ja
> &gt;va:684) at java.lang.Thread.run(Thread.java:568)
> &gt; Caused by:
org.geotools.arcsde.pool.UnavailableArcSDEConnectionException:
> &gt; The maximun of 8 to
> &gt;
user=DID,
> &gt; password=*****, minConnections=2, maxConnections=8,
connTimeOut=1000]
has
> &gt; been reached
> &gt; at
> &gt;
> &gt; at
> &gt;
> &gt;
> &gt;a:249) at
> &gt;
> &gt;
> &gt;4) ... 61 more
> &gt; 2008-02-20 11:17:03,301 DEBUG
> &gt; [org.geotools.arcsde.pool.ArcSDEConnectionPool] - Connection
validated,
> &gt; returned user DID
> &gt; 2008-02-20 11:17:03,301 INFO [org.geoserver.wfs] -
> &gt; Request: transaction
> &gt; handle = null
> &gt; service = WFS
> &gt; version = 1.0.0
> &gt; baseUrl = http://145.50.148.45:8082/geoserver/
> &gt; lockId = null
> &gt; group =
> &gt;
[net.opengis.wfs:insert=net.opengis.wfs.impl.InsertElementTypeImpl@anonymised.com
> &gt; (feature: [Feature[ id=fid-121efd4e_11831468923_-7fa3 ,
OBJECTID=null
> &gt; TITEL=null , DATUM=null , SHAPE=MULTIPOLYGON
(((135439.96200400835
> &gt; 421159.9247387089, 155040.01315245865 422279.9276614775,
148319.99561584712
> &gt; 400439.87066749, 135439.96200400835 421159.9247387089))) ]],
handle:
null,
> &gt; idgen: &lt;unset&gt;, inputFormat:
&lt;unset&gt;, srsName: null)]
> &gt; insert =
[net.opengis.wfs.impl.InsertElementTypeImpl@anonymised.com
OBJECTID=null
148319.99561584712
handle:
null,
> &gt; update =
> &gt; delete =
> &gt; native =
> &gt; releaseAction = ALL
> &gt;
> &gt; TIA.
> &gt;
> &gt; Best regards,
> &gt; Bart
> &gt;
> &gt; --
> &gt; Bart van den Eijnden
> &gt; OSGIS, Open Source GIS
> &gt; http://www.osgis.nl
> &gt;
> &gt;
> &gt;
> &gt;
> &gt;
> &gt;
> &gt;
> &gt; This SF.net email is sponsored by: Microsoft
> &gt; Defy all challenges. Microsoft(R) Visual Studio 2008.
> &gt; http://clk.atdmt.com/MRT/go/vse0120000070mrt/direct/01/
> &gt; _______________________________________________
> &gt; Geoserver-users mailing list
> &gt; Geoserver-users@lists.sourceforge.net
> &gt; https://lists.sourceforge.net/lists/listinfo/geoserver-users
> &gt;
> &gt; !DSPAM:4045,47bc2944165086491211187!
