[Geoserver-users] ArcSDE DataStore to KML Reflector Geoserver 1.7.2
I currently am using Geoserver 1.7.2 on Windows Server 2003.
I was able to get the following url to return data as a network link in
Google.
http://<server>.ca:80/geoserver172/wms?service=WMS&version=1.0.0&request=GetMap&format=application/vnd.google-earth.kml+XML&width=500&height=500&srs=EPSG:4326&layers=sde:bath7m&styles=Bathymetry&bbox=-180.0,0.0,-90.0,90.0
However the equivalent url -
http://<server>.ca/geoserver172/wms/kml?layers=sde:bath7m does not seem to
work as expected. (sde source)
Although this one does work..
http://<server>.ca/geoserver172/wms/kml?layers=sf:archsites (shapefile
source)
Error that seems to be occurring:
16:56:00,841 INFO [geoserver.action] - setting session and user ftConfig to
: FeatureTypeConfig[name: WHSE_BASEMAPPING.DBM_BC_7H_MIL_BATHYMETRC_POLY
alias: bath7m schemaName: bath7m_Type SRS: 4326 schemaAttributes:
[org.vfny.geoserver.config.AttributeTypeInfoConfig@anonymised.com,
org.vfny.geoserver.config.AttributeTypeInfoConfig@anonymised.com] schemaBase null]
2009-02-03 16:56:13,419 WARN [action.RequestProcessor] - Unhandled Exception
thrown: class javax.servlet.ServletException
2009-02-03 16:56:13,419 ERROR [[/geoserver172].[action]] - Servlet.service()
for servlet action threw exception
javax.servlet.ServletException: Action must be a MessageResource key value
of either 'label.edit' or 'label.delete'
Any idea as to what I am not doing right here?
Has anyone else had issues with SDE -> KML Reflector in Geoserver 1.7.2?
Many thanks!
View this message in context: http://www.nabble.com/ArcSDE-DataStore-to-KML-Reflector-Geoserver-1.7.2-tp21967542p21967542.html
Hi Michelle,
I am not sure the error below is the relevant error. That error seems to be originating from user interface access... which a call to kml is not. Are there any other errors in the log?
Also can you try the following url:
http://<server>.ca/geoserver172/wms/kml?layers=sde:bath7m&mode=refresh
It access the reflector in a different mode. It could be the default mode (regionating) that is the problem.
-Justin
Google.
source)
Many thanks!
Justin Deoliveira
OpenGeo - http://opengeo.org
Justin,
It looks like it does work with &mode=refresh option (This is with a polygon
layer).
Point SDE data seemed to work ok in the regionating mode.
I don't seem to get an error in the log when opening the URL in Google
Earth.
The layer icon spins as if refreshing in GE and then it eventually stops
with know features returned.
The verbose logging seems to do this over and over when trying the
regionating approach for the polygon layer..
16 Feb 10:56:39 DEBUG [geoserver.ows] - Getting layers and styles from
LAYERS and STYLES
16 Feb 10:56:39 DEBUG [geotools.styling] - number of fts set 1
16 Feb 10:56:39 DEBUG [geoserver.ows] - establishing Bathymetry style for
sde:bath7m
16 Feb 10:56:39 DEBUG [geoserver.kml] - scale denominator =
1.5564356888764769E7
16 Feb 10:56:39 DEBUG [geoserver.kml] - request = ReferencedEnvelope[-101.25
: -90.0, 33.75 : 45.0]
16 Feb 10:56:39 DEBUG [geoserver.kml] - top level = Env[-101.25 : -90.0,
33.75 : 45.0]
16 Feb 10:56:39 DEBUG [geoserver.kml] - Network link
00:http://delivery.openmaps.gov.bc.ca:80/geoserver172/wms?format_options=KMPLACEMARK%3Afalse%3BKMATTR%3Atrue%3BKMSCORE%3A50%3BOVERLAYMODE%3Aauto%3BSUPEROVERLAY%3Atrue%3B&width=256&transparent=false&version=1.1.1&service=wms&srs=EPSG%3A4326&styles=Bathymetry&height=256&superoverlay=true&bbox=-101.25%2C39.375%2C-95.625%2C45.0&request=GetMap&layers=sde%3Abath7m&format=application%2Fvnd.google-earth.kml%2Bxml
16 Feb 10:56:39 DEBUG [wms.responses] - setting up map
16 Feb 10:56:39 TRACE [arcsde.pool] - activating connection Session[24]
01:http://delivery.openmaps.gov.bc.ca:80/geoserver172/wms?format_options=KMPLACEMARK%3Afalse%3BKMATTR%3Atrue%3BKMSCORE%3A50%3BOVERLAYMODE%3Aauto%3BSUPEROVERLAY%3Atrue%3B&width=256&transparent=false&version=1.1.1&service=wms&srs=EPSG%3A4326&styles=Bathymetry&height=256&superoverlay=true&bbox=-95.625%2C39.375%2C-90.0%2C45.0&request=GetMap&layers=sde%3Abath7m&format=application%2Fvnd.google-earth.kml%2Bxml
10:http://delivery.openmaps.gov.bc.ca:80/geoserver172/wms?format_options=KMPLACEMARK%3Afalse%3BKMATTR%3Atrue%3BKMSCORE%3A50%3BOVERLAYMODE%3Aauto%3BSUPEROVERLAY%3Atrue%3B&width=256&transparent=false&version=1.1.1&service=wms&srs=EPSG%3A4326&styles=Bathymetry&height=256&superoverlay=true&bbox=-101.25%2C33.75%2C-95.625%2C39.375&request=GetMap&layers=sde%3Abath7m&format=application%2Fvnd.google-earth.kml%2Bxml
11:http://delivery.openmaps.gov.bc.ca:80/geoserver172/wms?format_options=KMPLACEMARK%3Afalse%3BKMATTR%3Atrue%3BKMSCORE%3A50%3BOVERLAYMODE%3Aauto%3BSUPEROVERLAY%3Atrue%3B&width=256&transparent=false&version=1.1.1&service=wms&srs=EPSG%3A4326&styles=Bathymetry&height=256&superoverlay=true&bbox=-95.625%2C33.75%2C-90.0%2C39.375&request=GetMap&layers=sde%3Abath7m&format=application%2Fvnd.google-earth.kml%2Bxml
16 Feb 10:56:39 INFO [geotools.map] - USing a deprecated method!
16 Feb 10:56:39 TRACE [geoserver.geosearch] - No attribute specified,
falling back on geometry attribute
16 Feb 10:56:39 DEBUG [geoserver.geosearch] - Requested tile:
ReferencedEnvelope[-101.25 : -90.0, 33.75 : 45.0]
16 Feb 10:56:40 DEBUG [geoserver.geosearch] - Found 0 features in tile Tile
X: 7, Y: 11, Z: 4 (ReferencedEnvelope[-101.25 : -90.0, 33.75 : 45.0])
16 Feb 10:56:40 INFO [geotools.map] - USing a deprecated method!
16 Feb 10:56:40 DEBUG [geoserver.filters] - filtering
http://delivery.openmaps.gov.bc.ca/geoserver172/wms
16 Feb 10:56:40 DEBUG [geoserver.ows] - Could not find kvp parser for:
'OVERLAYMODE'. Storing as raw string.
16 Feb 10:56:40 DEBUG [geoserver.global] - getting type sde:bath7m
16 Feb 10:56:40 DEBUG [geoserver.ows] - Getting layers and styles from
LAYERS and STYLES
Thanks for the help,
Michelle
Justin Deoliveira-6 wrote:
Hi Michelle,
-Justin
View this message in context: http://www.nabble.com/ArcSDE-DataStore-to-KML-Reflector-Geoserver-1.7.2-tp21967542p22043530.html
