[Geoserver-users] ArcSde problem
Hellow!
I'm using GeoServer 1.6.3 and the arcsde plugin. The probem is that the
plugin doesn't really work as it shoud. Here are 2 images where the problem
can be clearly seen.
This is the ok image:
http://www.shrani.si/f/1p/eC/4FGXU2AZ/arcsdeok.jpg
Now i pan a small amount to the right an this is what i get:
http://www.shrani.si/f/1X/BR/26iqWnW1/arcsdeerr.jpg
(Reference polys are marked with blue circle.)
Why would some geometry just dissappear?
View this message in context: http://www.nabble.com/ArcSde-problem-tp21410159p21410159.html
It seems i have found the solution for the problem. In ArcSDEQuery.java in
getSeQuery i replaced this
this.query.setSpatialConstraints(SeQuery.SE_OPTIMIZE,
setReturnGeometryMasks,spatialConstraints);
with this
this.query.setSpatialConstraints(SeQuery.SE_ATTRIBUTE_FIRST,setReturnGeometryMasks,spatialConstraints);
and all seems to be working.
View this message in context: http://www.nabble.com/ArcSde-problem-tp21410159p21435289.html
Hi GeoUser...
it seems tough, I don't think changing that flag should affect the result set,
but the speed of the query, if I remember well, as for what the esri
documentation says (ie, execute the alphanumeric filters first, the geometry
ones firts, or let the arcsde engine decide)...
Now, whether one or the other is better depends on the query, either the
attribute or spatial parts of a query may be faster and lead to less features
to filter in the next step..
The fact that it's affecting the result count for you makes me wonder if
changing that flag may solve the problem for your specific request and mess up
others... The only way I can think of to be sure is being able to reproduce in
a unit test. Could you give more information about the arcsde version,
database flavor and version, and the structure of the layer and the query
you're performing?
If you can even provide a data snapshot (shapefile is ok) I could try and see
what's going on.
Gabriel
with this
Demat Dit ! (Hello in Breton language)
I have a question about the getFeatureInfo Service :
Let's say I would like to get informations about some feature(s) but I would like GeoServer to return only a set of selected attributes from my features table. I suppose it is done in the FeatureType configuration but I could not find how. Could someone enlight me on this ?
Thanks.
Gilles
-----Message d'origine-----
De : Gabriel Roldan [mailto:groldan@anonymised.com]
Envoyé : mardi 13 janvier 2009 23:20
À : geoserver-users@lists.sourceforge.net
Objet : Re: [Geoserver-users] ArcSde problem
Hi GeoUser...
you're performing?
what's going on.
Gabriel
with this
This SF.net email is sponsored by:
SourcForge Community
SourceForge wants to tell your story.
http://p.sf.net/sfu/sf-spreadtheword
Geoserver-users mailing list
I have a question about the getFeatureInfo Service : Let's say I
There is no way to completely hide attributes from GetFeatureInfo
but not, say, to the map renderer.
You can use a custom templates for the HTML output, but all
the attributes will be still visible using the text or gml2
GetFeatureInfo output format.
I guess you have sensitive information that you still need
to build the map? If the map can be drawn without those,
then you can store your data into a database, and build a
view that only returns the data you want to share with
the world, and use the view as your data source.
You can also make a feature request on jira.codeahus.org,
if enough people vote it or if someone sponsors it, it
will be eventually implemented into GeoServer.
Hope this helps.
Andrea Aime
OpenGeo - http://opengeo.org
say I would
my features
GetFeatureInfo but not, say, to the map renderer.
I guess you have sensitive information that you still need to
build the map? If the map can be drawn without those, then
you can store your data into a database, and build a view
that only returns the data you want to share with the world,
You can also make a feature request on jira.codeahus.org, if
enough people vote it or if someone sponsors it, it will be
... and GeoServer would be even with MapServer that has total control on
items shown by getFeatureInfo. Meanwhile I'd suggest also building a
view.
-Jukka Rahkonen-
Hi Gabriel,
I am not a GeoServer user, my apologies :-), but seem to be having some
issues like this and am in contact with ESRI support right now, so I can
post any resolution I have.
To outline my issue, I use the Java API to spatially query a layer of 600K+
features to overlay a shape and pull back an attribute for intersected
features. My issue is with SE_OPTIMIZE. Using this setting only ever gives
me back only one feature, in a normal response time. If I switch to
SE_ATTRIBUTE_FIRST, I get back 23 features, which is correct, but works
EXTREMELY slowly - we're talking a slowdown factor of about 200 times.
It's obvious from tracing (and common sense) that:
1. With SE_OPTIMIZE, the spatial index is being used, but I cannot fetch
more than one feature.
2. With SE_ATTRIBUTE_FIRST, the spatial index is NOT being used and a full
table scan is occurring. NOTE that this also happens if
SeQuery.prepareQuery() is placed AFTER SeQuery.setSpatialConstraints() -
which is another 'fix' I've used.
I've used a layer containing only the 23 target features as my query layer
and gotten the same results. Obviously, the full table scan here is
imperceptible.
I suppose all this is to say that you are right - the SE_ATTRIBUTE_FIRST is
a cover up for an underlying issue. It's a horrible kludge and would
severely degrade performance on larger layers. Thank heavens it's there,
but it definitely isn't the 'solution'.
All the above may only apply to my setup, of course - ArcSDE 9.3 Server on
Oracle 10g 64 bit, using SDE geometry, but I thought I'd pass it on.
If you get any answers to this issue, could you let me know?
Frank
Gabriel Roldan wrote:
Hi GeoUser...
set,
geometry
features
mess up
reproduce in
you're performing?
see
what's going on.
Gabriel
in
with this
View this message in context: http://www.nabble.com/ArcSde-problem-tp21410159p22805132.html
humm... first off, thanks for sharing this information Frank..
some comments inline
FrankMcLean wrote:
Hi Gabriel,
no need to apologize, though I know what you'll chose when you need a geospatial server :slight_smile:
please!!
ok, I assume SE_SPATIAL_FIRST is giving the same result then SE_OPTIMIZE then?
yet, it really sux that they return different results... I can understand (and was my understanding) that both should return the same results but may be more or less convenient depending on the attribute/spatial filters mix up (attribute first and spatial first, that is), and optimize should let arcsde decide which of the two to use based on the filter predicate complexity...
now this opens a new horizon of uncertainty for me too... Question: that does happen _always_? or it does for some datasets and for others the same results are returned?
also, are you mixing attribute and spatial filters at all?
and the _correct_ result for the spatial (and attribute?) filter you're using is the 23 features or the single one? (you said the 23, I'm just double checking)
sad that's not my common sense, but to use the spatial filter first and still return the correct number of features...
my understanding was that it should execute the alphanumeric part of the query on the database first, but that doesn't imply a full table scan should be _needed_. It should leverage the indexes as long as they exist? do you have indexes created on the db table for the non spatial attributes you're querying? sorry it may be a very dumb question but I'm still trying to make my head around this weirdness...
imperceptible.
With all the respect I have for arcsde... I still think the indexes should be used instead of a full table scan whenever possible, but I certainly remember a former customer having lots of issues trying to make sde actually use the indexes... unfortunately I don't know/remember what the resolution was.
thanks again for sharing, and please if you get to any conclusion tell us back.
sure, I wish I get some more time to research/experiment with this. I'm perhaps going to have some in the short term.
Best regards,
Gabriel
Frank
Hi GeoUser...
set, but the speed of the query, if I remember well, as for what the esri documentation says (ie, execute the alphanumeric filters first, the
geometry ones firts, or let the arcsde engine decide)...
Now, whether one or the other is better depends on the query, either the attribute or spatial parts of a query may be faster and lead to less
features to filter in the next step..
The fact that it's affecting the result count for you makes me wonder if changing that flag may solve the problem for your specific request and
mess up others... The only way I can think of to be sure is being able to
reproduce in a unit test. Could you give more information about the arcsde version, database flavor and version, and the structure of the layer and the query you're performing?
see what's going on.
Gabriel
in
with this
Hi Gabriel,
My comments to your comments, kind of inline:
then?
Precisely.
That's my reading also.
Question: that
I've not tried it on other datasets, due to a lack of time, but I suspect it
would, given that the subset layer exhibits the same problem and various
subs of this sub do too, so the spatial index grid values seem to have no
bearing. Tracing _seems_ (to my uneducated eyes) to indicate that Oracle
provides 23 results from the initial table query to ArcSDE, but I only fetch
1 back. The underlayng feature shapes are in no way wierd.
Yeah, sorry, you'd need more info from my to apply common sense - here I'm
saying that the query is lightning fast, so an index is being used, but
sadly I only end up with one result.
should be _needed_.
Yes, again, if I'd given you more info, to whit, that my query is purely
spatial, so there's no attribute to use, you'd get the full table scan bit.
I'm sure Oracle would use an index if I'd specified a where clause.
From what I'm seeing, all of the query planning is being done by Oracle -
ArcSDE just issues a query like 'select blah from blee where bloh' and
Oracle takes it from there. I take it from that that indexes should be used
whereever appropriate. The 'spatial grid index' is a separate table that
ArcSDE creates and indexes and then queries like any other table, somewhat
like 'select rowid.of.feature.in.layer from index where
index.minXofLayerShape >= givenshapeMinx and index.minYofLayerShape (etc)'.
It then takes the returned rowids and fishes them out from the layer before
reviewing candidate shapes for a final match. Again, Oracle should be
making the best use of indexes on the spatial 'index'.
I will certainly post any resolution I get from ESRI. I'm hoping it's a
setup problem, but we'll see. The fact that ArcMap doesn't show the issue
is rather worrying from that point of view...
All the best,
Frank
FrankMcLean wrote:
Hi Gabriel,
please!!
600K+
gives
then?
double checking)
full
layer
imperceptible.
is
on
us back.
Best regards,
Gabriel
Frank
Hi GeoUser...
result
set,
geometry
features
mess up
reproduce in
query
you're performing?
and
see
what's going on.
Gabriel
in
with this
View this message in context: http://www.nabble.com/ArcSde-problem-tp21410159p22847434.html
Hi Gabriel,
Well, after much back and forth with ESRI support, who cannot reproduce my
issue, even with my code, I found a workaround:-
Make sure the SHAPE column is in the query list, whether you're going to use
it or not.
The 'problem' was that my query does not care one bit about the shape of a
feature, just one of its attributes, meaning that I did not include the
SHAPE column in my query list. According to ESRI, this is perfectly fine
and the code I sent them produces the correct number of features in their
setup. In my environment, however, I only get the one feature returned. If
I ensure that all queries include the SHAPE column, whether or not this is
just fluff to subsequent code, the query runs fine - the right number of
features, delivered lightning fast.
So I'm happy and my ulcer is shrinking. I should say that when I applied
this fix to my code, it became obvious that my previous 'fix'
(SE_ATTRIBUTE_FIRST) was producing some odd behaviour in other places, which
is another reason this practise should be discouraged (when used to
workaround oddness).
I'm still talking to ESRI about a possible fix to the SDK, so I'll let you
know.
Frank
View this message in context: http://www.nabble.com/ArcSde-problem-tp21410159p22957614.html
Hi Frank,
glad you get it working and thanks for sharing!
so, to recap, it seems like you were making a query with a single spatial (bbox) filter but you weren't asking for the geometry attribute to be returned, hence this lead to the shape att not being requested and ArcSDE not using the spatial filter and giving inaccurate results? Or did I get it wrong?
Also, if it's not asking for too much, could you please add a jira issue <http://jira.codehaus.org/browse/GEOT&gt; for the data-arcsde module, assigned to me, explaining the issue and the resolution? It seems to me, if my understanding was correct, that whenever a spatial filter is used we should ask for the geometry attribute even if its not going to be used?
best regards
Gabriel
FrankMcLean wrote:
Hi Gabriel,
it or not.
know.
Frank
