[Geoserver-users] ArcSDE working in 1.6RC2
Sorry this is the full exception log:
2008-01-15 16:58:10,780 ERROR [[/geoserver].[action]] - Servlet.service()
for servlet action threw exception
java.lang.NullPointerException
        at java.lang.Class.isAssignableFrom(Native Method)
        at
org.geotools.feature.DefaultAttributeTypeFactory.createAttributeType(DefaultAttributeTypeFactory.java:111)
        at
org.geotools.feature.AttributeTypeFactory.newAttributeType(AttributeTypeFactory.java:73)
        at
org.geotools.data.arcsde.ArcSDEAdapter.createAttributeTypes(ArcSDEAdapter.java:425)
        at
org.geotools.data.arcsde.ArcSDEAdapter.fetchSchema(ArcSDEAdapter.java:287)
        at
org.geotools.data.arcsde.ArcSDEDataStore.getSchema(ArcSDEDataStore.java:202)
        at
org.vfny.geoserver.action.data.DataFeatureTypesNewAction.execute(DataFeatureTypesNewAction.java:84)
        at
org.vfny.geoserver.action.ConfigAction.execute(ConfigAction.java:101)
        at
org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:431)
        at
org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:236)
        at
org.apache.struts.action.ActionServlet.process(ActionServlet.java:1196)
        at
org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:432)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
        at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:252)
        at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:173)
        at
org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
        at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:202)
        at
        at
org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
        at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
        at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
        at
org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
        at
org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
        at
        at
org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
        at
        at
org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:142)
        at
        at
org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:81)
        at
        at
org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:217)
        at
        at
org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:106)
        at
        at
org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
        at
        at
org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
        at
org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
        at
        at
        at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
        at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:178)
        at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:126)
        at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:105)
        at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:107)
        at
org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:526)
        at
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:148)
        at
org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:856)
        at
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.processConnection(Http11Protocol.java:744)
        at
org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(PoolTcpEndpoint.java:527)
        at
org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt(LeaderFollowerWorkerThread.java:80)
        at
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:684)
        at java.lang.Thread.run(Thread.java:568)
Best regards,
Bart
Bart van den Eijnden
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: Bart van den Eijnden OSGIS <bartvde@anonymised.com>
Naar: Andrea Aime <aaime@anonymised.com>, Bart van den Eijnden OSGIS
Onderwerp: Re: [Geoserver-users] ArcSDE working in 1.6RC2
Datum: 15/01/08 13:43
Hmm, after adding this I can't create a featuretype anymore on SDE, this
did
work before the change:
The following exception was thrown:
java.lang.NoSuchFieldError: org.geotools.filter.Filter: field NONE not
found
Or:
15 Jan 16:41:17 WARN [org.vfny.geoserver.global] - Suppressing StdOut
logging. If you want to see GeoServer logs, be sure to look in
'/var/tomcat/webapps/geoserver/data/logs/geoserver.log'
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
15 Jan 16:41:21 WARN [org.vfny.geoserver.global] - Suppressing StdOut
Jan 15, 2008 4:41:39 PM org.geotools.data.arcsde.ConnectionConfig
checkParams
WARNING: No database name specified
checkParams
Jan 15, 2008 4:41:48 PM org.geotools.data.arcsde.ArcSDEAdapter
WARNING: Figured Row-ID Column named 'OBJECTID' for table
TOPOGRAFIE.DTB_VLK
Best regards,
Bart
http://www.osgis.nl
Van: Andrea Aime &lt;aaime@anonymised.com&gt;
Naar: Bart van den Eijnden OSGIS &lt;bartvde@anonymised.com&gt;
Datum: 15/01/08 13:20
&gt; Bart van den Eijnden (OSGIS) ha scritto:
&gt; &amp;gt; Hi list,
&gt; &amp;gt;
&gt; &amp;gt; I am trying 1.6RC2 against ArcSDE (9.1 libs), but I can't
get it to
work.
&gt; ....
&gt; &amp;gt; Does this ring a bell for anyone? TIA.
&gt;
&gt; http://jira.codehaus.org/browse/GEOS-1648
&gt;
&gt; I believe you can fix it by downloading jsqlparser from here:
&gt;
http://lists.refractions.net/m2/jsqlparser/jsqlparser/0.3.14/jsqlparser-0.3.14.jar
&gt; and adding it into web-inf/lib.
&gt;
&gt; Cheers
&gt; Andrea
&gt;
&gt;
