[Geoserver-users] Are ScaleHints and Min&Max denominators broken in WMS?
My local Geoservers 2.5.2 and 2.6.0 do not send ScaleHints or MinScaleDenominator/MaxScaleDenominators with GetCapabilities like this older demo server does:
http://demo.opengeo.org/geoserver/wms?service=WMS&request=GetCapabilities&version=1.3.0
http://demo.opengeo.org/geoserver/wms?service=WMS&request=GetCapabilities&version=1.1.1
-Jukka Rahkonen-
On Wed, Oct 8, 2014 at 9:40 AM, Rahkonen Jukka (Tike) <
jukka.rahkonen@anonymised.com> wrote:
Just made a quick verification with trunk code, I have the scale
denominators showing up in the wms 1.3
document.
Make sure that:
* you have a layer with a style that does not display at all outside of
certain scale ranges
* that style is the only one attached to the layer, or else, if you have
others, make sure they are also not displaying in some scale ranges, and
that of course
  there are scale ranges in which none of the styles shows up (what you get
is exactly that)
As a counter example, say you have a layer that has scale dependencies in
its default style, but you also associated an alternative style that
shows everything at any scale (e.g., point/line/polygon), in that case the
scale ranges won't appear in the caps document.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
