On Tue, Feb 10, 2015 at 12:02 PM, emmexx <emmexx@anonymised.com> wrote:
I'm using the following rest call to get a list of features. I wanted to
limit the attributes returned and added propertyName to the request:
http://example.com:8080/geoserver/bicitalia/ows?service=WFS
&version=1.0.0
&request=GetFeature
&typeName=myworkspace:mylayer
&maxfeatures=50
&outputformat=application%2Fjson
&propertyName=attribute1,attribute2,geom
The problem is I get other fields too.
"type":"Feature",
"id":"an_id",
"geometry":{"type":"MultiLineString",
"coordinates":[[...]]},
"geometry_name":"geom",
"properties":
"attribute1":4,
"attribute8":5,
"attribute6":false,
"attribute2":"52",
"attribute11":false
Why is that?
I'm using geoserver 2.5.
Most likely, because they are declared as mandatory in the xml schema
returned by DescribeFeatureType,
which normally means you have them marked as non nullable in your database.
If this is the case, you can maybe create a sql view, they will be all
treated as nullable in that case.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
