[Geoserver-users] Authentication Problem Geoserver Realm
i have a Geoserver 2.8 (deployed on Tomcat 7) behind an Apache Webserver.
The Apache has a htaccess for http://serverWithTomcat/geoserver/*
The authentication on the Apache is done against a Ldap directory and works
fine. After the authentication from the Apache i get another authentication
for Geoserver Realm. After the geoserver realm authentication i get another
authentication from the apache and so on. The authentications don't fail, i
guess it has to be some kind of session/redirect problem.
We have to keep the authentication at the Apache, because the Apache is in
our DMZ. Can i turn off this geoserver realm authentication and just keep
the authentication for login to the backend?
Max
View this message in context: http://osgeo-org.1560.x6.nabble.com/Authentication-Problem-Geoserver-Realm-tp5253606.html
can you describe a bit more your use case? Are you trying to authorize
OGC service calls? Or is it just the administration UI that you’re trying to get into?
In any case, I believe you should connect to GeoServer directly first, and then
setup proxy authentication so that GeoServer uses and trusts the authentication
performed by Apache:
http://docs.geoserver.org/latest/en/user/security/tutorials/httpheaderproxy/index.html
On Tue, Mar 1, 2016 at 2:27 PM, fmd.85 <fmd85@anonymised.com> wrote:
authentication from the apache and so on. The authentications don’t fail, i
Max
Site24x7 APM Insight: Get Deep Visibility into Application Performance
APM + Mobile APM + RUM: Monitor 3 App instances at just $35/Month
Monitor end-to-end web transactions and take corrective actions now
Troubleshoot faster and improve end-user experience. Signup Now!
http://pubads.g.doubleclick.net/gampad/clk?id=272487151&iu=/4140
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
